BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > Buying a car with out of state plates
      09-11-2020, 08:38 PM   #1
bmwchue
Drives: 2013 bmw 328i
found this nice bmw x5 near me but the seller never registered the car and still has Ohio plates on it. What is the process to register it in california. thanks
      09-11-2020, 09:02 PM   #2
learntocode
https://www.dmv.ca.gov/portal/uploads/2020/06/htvr9.pdf
      09-12-2020, 09:52 AM   #3
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Same as buying used.. Need a smog check and a legit pink slip to register.
      09-12-2020, 05:45 PM   #4
bmwchue
thanks seems like alot of work
      09-16-2020, 03:37 PM   #5
exE36M3
BMW CCA Member
exE36M3's Avatar
347
Drives: 2015 435i M Sport
Yes/no. I bought an out of state car. All you really need to do is get it smogged. If it passes, you can re-register it in CA. Everything else is registration, title, etc. from the previous owner (much like CA).
Personally, given it's from Ohio, I'd have a GOOD look under the car. Snow and salt does some bad things to underbodies of cars.
bmwchue222.50
      09-17-2020, 11:16 PM   #6
chambo622
Drives: F31 LCI 328i M Sport EBII
I bought a car from out of state back in July. Keep in mind that you need a VIN inspection as well, which isn't the case for buying cars in CA. Due to COVID the DMV wasn't doing VIN inspections for quite a while, but they finally are now, I was able to get one done. Between smog and the VIN verification it's a bit more hassle but overall not a big deal.
      09-18-2020, 11:13 PM   #7
Gen13 F36
Gen13 F36's Avatar
One more think to add... You only do all this thing mention above when you are buying from a private seller.
If your buying from a dealer, they going to do all this for you... Only thing you gonna do is sign papers and drive the car home or get it transported. I bought a car this way from Texas.... Drove it home to LA.
bmwchue222.50
