BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > SOLVED!!! HALO Brightness %100 with lowbeams F30LCI NON ADAPTIVE LED HEADLIGHT
      05-18-2016, 07:34 AM   #45
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Originally Posted by matteis View Post
dmnc02
I got missed CAF file. Here is an image showing how it looks like:
I'd like to have 100% Angel eyes intensity with low beam. What parameters do I have to change?
I would need to see the NCD file to be sure, but, based on the limited info in your screenshot, try changing POLI1_Idx, POLI2_Idx and POLI3_Idx in both FLEs from
01, 01, 01, 01, 01, 01, 04, 01, 01, 01
to
01, 01, 01, 01, 01, 01, 03, 01, 01, 01
2015 Mineral Grey ///M4 6MT
      05-18-2016, 02:41 PM   #46
phattbam
Drives: '17 Protonic Blue i3 REx
Originally Posted by dmnc02 View Post
You can turn them off as position lights but still use them as signal lights.
In TMS, change both Standlicht Modus 1 and Modus 2 to
00, 03, 00, 00, 64, 03, 00, 00, 00, 03, 00, 00, 2E, 04, 00, 00.
Do the same change in Welcome Light 1 if you don't want to have them turn on with the welcome lights either.
Thank you. i will need to try this on my MY15 335i.
      05-18-2016, 04:00 PM   #47
matteis
Drives: bmw 118i f20 sport gp
to
Tks.
I do not have NCD file yet cause car is not mine. As soon as I get it, I'll post it here.
If you dont mind to explain, what I'm doing when I change this values or where can I "learn" about it?
      05-18-2016, 05:01 PM   #48
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Tks.
I don't mind. I posted on the other forum a few months back to explain how FLE is structured and how the new ECU is different from the old ECUs (LHM+TMS) on the pre-LCI F30. You can find the post here.
      05-18-2016, 11:29 PM   #49
matteis
I'll do my "homework". Tks again
      05-19-2016, 03:18 AM   #50
matteis
to
I'll try to code it this weekend and I'll post the results here (I'll be able to get NCD file to). Do I have to change any value in lmmIdx_15 Pryority and Intensity as well?
And, sorry for the dummy question, but we're talking about FDL coding, right?
      05-19-2016, 04:24 PM   #51
marcospoffo
marcospoffo's Avatar
Brazil
17
Drives: 320 F30 - 2013
Fala jovem beleza? Esses dias você me perguntou sobre o coding dos angels que não estava dando certo em uma 120.
O problema está que nos modelos que já são LCI, não esta aceitando no Fem_body como você já percebeu.
Por coincidência eu te encontrei aqui no fórum gringo
É você né? Só encontrei esse tópico ontem. Até então eu não tinha descoberto como fazer.
Lá deu certo para as F30, mas como na F20 o Wert está diferente o cara te ajudou lá passando o possível código para você.
Você vai testar esse final de semana? Se possível você pode dar um parecer se deu ou não certo? no momento eu não tenho nenhum carro pra testar.
Valeu brother
320 F30 2013.
      05-19-2016, 04:31 PM   #52
dmnc02
dmnc02's Avatar
Drives: 2015 M4
No, you only need to change POLI1_Idx, POLI2_Idx and POLI3_Idx: nothing else.
Yes, it is FDL coding, although you will need to edit the Werte values directly rather than select pre-defined literal values.
      05-21-2016, 04:05 PM   #53
phattbam
This would work on my pre-LCI?
would the brows and regular orange signal lights flash at the same time when used now?
      05-21-2016, 05:11 PM   #54
dmnc02
dmnc02's Avatar
Drives: 2015 M4
This particular coding would only work on a pre-LCI (there is no TMS ECU on the LCI).
I believe (but I am not 100% sure) that the eyebrows will still flash with the signal lights.
      05-30-2016, 10:51 PM   #55
matteis
to
I've coded finally. Everything worked flawless.
The settings above were used to code a f20 2016 125iM
dmnc02 Tks for the help!
      05-31-2016, 08:51 AM   #56
mtx450
mtx450's Avatar
Drives: 2011 E90 M3 ZCP
2011 BMW M3  [0.00]
Just to ask a stupid question, but does this actually increase (noticeably) the light output of the headlights or is it just visual appeal? I know this is just the rings, but any increased light output from the LED's would be great. They aren't as good as I thought they would be (now after driving the car for 3 weeks).
      06-01-2016, 06:42 PM   #57
marcospoffo
Brazil
17
In f30 328i 2016.
Any idea how to do?
03, 03, 03, 03, 03, 03, 0B, 03, 03 ,03
320 F30 2013.
      06-01-2016, 11:21 PM   #58
dmnc02
dmnc02's Avatar
Drives: 2015 M4
It increases the light output somewhat, but it is mostly for visual appeal.
The best way to really improve the performance of the LED's (if you have the adaptive ones with HBA) would be to code NGHB.
      06-01-2016, 11:24 PM   #59
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Originally Posted by marcospoffo View Post
In f30 328i 2016.
Any idea how to do?
Try changing the 7th byte in POLI1_Idx, POLI2_Idx and POLI3_Idx from 0B to 0A.
      06-02-2016, 12:03 AM   #60
kromix
kromix's Avatar
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
What is NGHB?
      06-02-2016, 07:41 AM   #61
dmnc02
dmnc02's Avatar
Drives: 2015 M4
Originally Posted by kromix View Post
What is NGHB?
Sorry: No-glare (or no-dazzle) high beams.
      06-07-2016, 01:29 PM   #62
marcospoffo
Brazil
17
I'll try. Thank you
How would you put in 50%?
I could not understand the logic. It seems to me that each model has different Hex
320 F30 2013.
      06-07-2016, 01:39 PM   #63
dmnc02
dmnc02's Avatar
Drives: 2015 M4
I'll try. Thank you
That is correct. As I mentioned at the beginning of this thread (post #4),
With the FLE ECUs, changing the brightness of a LED module (e.g., DRL) is no longer a matter of changing the Werte value of a predefined parameter to desired intensity (as it should be clear from the OP), so you have to take into account how the rest of the ECU is coded.
Read the post I linked in post #48 if you want to understand the logic behind the way FLE is coded.
      08-12-2016, 12:01 AM   #64
whyycharles
Drives: 2019 M4CS | 2020 x7 40i
I have a 2016 Bmw 340xi , how do i change the angel eyes brightness when low beams are on? I cant find the POLI1_Idx files in my SVT Tree?
      08-12-2016, 01:15 AM   #65
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
POLI1_Idx is the function parameter name found in FLE ECU.
      08-12-2016, 02:14 PM   #66
whyycharles
For my POLI1_Idx , POLI2_Idx, and POLI3_Idx the values are
00, 00, 00, 05, 00, 00, 06, 00, 00, 00
So what do i change to get it at 100% brightness ?
