BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 Downpipe Install Help
proTUNING Freaks
      02-14-2020, 04:14 PM   #1
1slow320
1slow320's Avatar
Drives: 2014 F30 320i
  [0.00]
So I went under my car to see what I was working with and I noticed that there was a weld on the exhaust side clamp. I didn't really try to remove it because I wasn't ready for the install but should it be a problem? Or would I need to bring it to a shop?
2014 F30 320i | BM3 Stage 2 | xHP Stage 3 | Euromotive Catless Downpipe | GPlus FMIC | MAD Chargepipe | GFB DV+ | 335i Muffler & Resonator Delete
      02-14-2020, 07:17 PM   #2
canman111
Drives: F30 328i RWD
2014 BMW 328i  [0.00]
Na I had the same weld on mine.
You can still take it out.
The weld just holds the clamp to the exhaust.
After you remove the bolt you can wiggle the exhaust apart.
Also I needed a deep socket for that bolt because mine was really stuck.
      02-14-2020, 08:15 PM   #3
1slow320
1slow320's Avatar
  [0.00]
Thanks. It was weird seeing it I thought maybe there was a leak and it had to be welded at some point
