BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > My California Smog Test Experience With A Modded Vehicle
      03-13-2024, 04:10 PM   #1
suprfly
Drives: 2016 BMW 340i M-Sport RWD
I thought I'd share my experience smogging my modified car in Los Angeles, CA. I hope that some users on this forum will find this thread useful.
I purchased my car completely stock in early 2021 and quickly began modding it since I didn't have to worry about a smog check until 2024.
Mods:
MST intake
AWE cat-back exhaust
CG Precision DS-1 hi-flow race catted downpipe
bootmod3 stage 2 tune
x-hp stage 2 transmission tune
I don't run the car on any E85 blends - just an OTS Stage 2 map w/ 91 ACN fuel.
I flashed the car back to stock and re-locked the DME via bootmod3. I drove it for approximately 60 miles and went straight to a smog place that I called ahead of time to see if they performed 'pre-tests'. Pre-tests, for anyone that doesn't know, is when the smog tech tests the car without the results being sent to the DMV. In this case, he hooked up an OBD scanner/tool to the car and scanned everything to see if all the systems were ready or not.
I passed the pre-test and decided to proceed with the official test. I was pretty nervous because here in CA if you fail the smog check you can be referred to the state referee which isn't fun.
Anyways, I passed. He did ask me if I had any aftermarket parts on the car and I said no. I did not witness the tech go around my car with a mirror to look under the vehicle which was a relief - I assume my reply to his question was sufficient for him.
I hope this helps someone out
      03-14-2024, 09:04 PM   #2
nosam1g
nosam1g's Avatar
66
Drives: 2018 340i
looks about right , pass with high flow cat , exhaust , and intake. Cat less will not pass/if they inspect for carb etc
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD
      03-15-2024, 02:29 AM   #3
DreamerJoe
Drives: 2017 340i M.G. w red interior
I usually find a place to slip $150 and they make it pass. Only thing is last friend I sent to my spot, where I paid $150 3 years ago, charged him over $300. With the whole smog abatement thing my 8 years is up next year. Thank you for the post 🙏 I’m catless though so screwed.
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      03-18-2024, 06:16 PM   #4
4coupe440i
Drives: BMW 4 series
Just do the pre-test yourself! Use your BM3 adapter to check the EOBD sensor readiness state.
      03-18-2024, 10:18 PM   #5
SpoolinAddict
Drives: 2015 F30 335i Stage 2 BM3
You check this through BM3 app?
can you check through bimmerlink?
I only have a veapeak bluetooth adapter and a enet adapter
      03-19-2024, 09:56 AM   #6
4coupe440i
MHD can show it so I assume BM3 can do the same...
View post on imgur.com
      03-19-2024, 10:46 AM   #7
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Catless passes for me no issues with spacer. Flashed back to stock tune, no locking DME. Pre-test done myself until all green and go to shop. No issues.
      03-20-2024, 07:48 PM   #8
SpoolinAddict
do you have to have a license or can any android user just download it and check readiness. I'm on bm3
      03-21-2024, 12:44 AM   #9
DreamerJoe
Really? I’m in California and curious if that would work for me as well. Do different states allow for different levels of emmisions? What draws the lines? I know some states just don’t give a F, like texas, and can problem drive a nascar if it had lights and blinkers
      03-21-2024, 06:38 AM   #10
pauli18c
pauli18c's Avatar
Drives: 2017 340i RWD M Sport
In Illinois as long as there's no check engine light, (Aka all the readiness monitors are set, or turned off via a tuner) you will pass. They don't actually smog test the tailpipe anymore.
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup
      03-21-2024, 04:01 PM   #11
SpoolinAddict
You won't pass with catless unless you know the smog tech. You won't pass visual and readiness monitor. They also check for tunes
I think most states are similar but CA is more strict
california, dmv, registration, smog, smog inspection, smog test
