03-17-2024, 11:57 AM | #1 |
Rep 92
Is a flex fuel kit needed for running e50 on gen1 b58 with ds2.5 or is the stock lines etc capable of running ethanol?
03-17-2024, 02:21 PM | #2 |
Rep 329
no , a flex fuel kit allows you to run 91 to e85 without adjusting your map(it selfs tunes base on the gas-ethanol in the tank). The stock lines you can run full e85 to 91.
Im assuming your on boot mod3 ? mhd gos up to e40 on stg2+ and full e85
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD |
03-17-2024, 03:58 PM | #3 |
Rep 92
Yes my plan is to have a map for e50 and a map for like 93.
03-17-2024, 05:48 PM | #4 |
Rep 5,392
BMW fuel systems for decades have been made with components that are compatible with ethanol.
FYI It would be archaic to have separate tunes for 93 and E50, and have to reflash to change tunes. It’s so much simpler to install a FlexFuel sensor. Then just flash Bootmod3 Stage2/2+ MultiMap and set it internally to 93 Octane. When a MultiMap tune sees an ethanol sensor it automatically scales the tune from its minimum (93 in this case) up to whatever percentage of ethanol is in the tank. The goal is to obtain the maximum performance from whatever fuel the engine is receiving. Of course the engine must have whatever hardware upgrades are necessary to run the grade of fuel in the tank such as HPFP, LPFP AND Fuel injectors. |
03-18-2024, 08:15 AM | #6 |
Rep 72
...yeah, and with the multi map, you don't need to reflash, you can just switch in real time using the Res cruise control button and the Tach readout.
I am will be getting the BM3 flex fuel kit eventually, but right now, everything is running fine without it and I just switch between maps on the fly when I fill up depending on what I have available to me. So for me having the Stage 2+ multi map with 91, 93, E30, and E50 tunes is perfect for me. I have VRSF catless downpipe, TU pump, and RKTunes FM CAI... |
03-18-2024, 09:32 AM | #7 |
Rep 329
Wait a sec.. so you got a upgraded turbo and your using ots maps? Def get a custom tune lol .. highly recommend getting flex fuel or tuner might charge to tune multi maps .. as if you had flex it would be 1 map 91 to e50 upgraded turbo. Flex fuel is a sensor that gos from you lpfp to hpfp by the firewall and a power unit stored in brake area
2011 335is - SOLD |
03-18-2024, 09:35 AM | #8 | |
Rep 92
03-18-2024, 09:38 AM | #9 |
Rep 92
03-18-2024, 10:10 AM | #10 |
Rep 329
idk id recommend flex fuel kit , its 500 bucks , and will be better in long run. some tuners charge based off 1 map ex. tune for 91 $300 tune for e50 ex $300 ... ex flex fuel $600
2011 335is - SOLD |
03-18-2024, 10:14 AM | #11 |
Rep 92
03-18-2024, 10:15 AM | #12 |
Rep 329
get flex trust ^^
2011 335is - SOLD |
03-18-2024, 10:34 AM | #14 |
recovering e36er
65
Rep 106
Drives: 2017 M240i Xdrive
I don't recommend a flex fuel kit
Kern417 touches on this in one of his flex fuel videos too. Essentially you'll lose one of the advantages running ethanol gives us as tuners. Some of us with ethanol tunes and $hitty local 93 actually need to run a higher percentage of ethanol in the mix than the map targets for knock protection. For example I run an E45-E47 mix on E40 map in MHD per recommendation of MHD. If I run eE40 on that same map, I get noticable timing pull on all cylinders. Running the higher mix will clear it up, or yield negligible pull on one or two cylinders. To each their own, I'm a bit OCD, I have the Spool analyzer to watch my ethanol content, yet i still least measure the ethanol content of the e85 out of the pump at least once a month.
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2 To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit |
03-18-2024, 11:02 AM | #15 | |
Rep 92
03-18-2024, 11:07 AM | #16 |
Rep 92
03-18-2024, 11:11 AM | #17 |
recovering e36er
65
Rep 106
That is correct, the standard e30 tune works better than flex fuel e30 tune, especially like 60-130 runs
E30 ots tune is targeted specifically for that function The flex fuel map does not challenge the targets as intently as the ots map does. Something about how the tune automatically tapers its targets throughout the E range
03-18-2024, 11:14 AM | #18 | |
Rep 92
04-20-2024, 05:30 AM | #19 |
Rep 72
So I got my BM3 flex fuel kit installed... Just my personal experience so far but my car pulls much harder than it did without it (maybe there is some factor about my situation that caused this).
This was just right out of the driveway. I didn't change my tune, only turned on FlexFuel since I had disabled it and manually told the DME I was running E30. Started the car and drove down the street. Before, I could do a a pull with just a little clutch slippage (BM3 MultiMap Stage 2+ E30), now, with the FlexFuel kit enabled my clutch slips anywhere after about 40-50% throttle! I can't even wide open throttle and that is in comfort mode. Sport and Sport+ are useless. (Obviously, next purchase is an upgraded clutch...) But my point is, in my situation, my car truly is running better with the kit feeding E information to the DME. 🤷🏻 |
04-21-2024, 04:52 PM | #20 | |
recovering e36er
65
Rep 106
I've been running the ds25 for almost a month now Car is really happy E49-E51ON e40 map Log from earlier today https://datazap.me/u/dantesboyz/yes?...46-47-48-49-63
04-21-2024, 05:22 PM | #21 | |
Rep 92
