09-25-2020, 02:55 AM | #1 |
Rep 308
435i exhaust options?
Hi guys,
Just bought a 435i and the previous owner did a muffler delete. The car is too loud IMO and I want to make it pretty much like stock or maybe a bit louder than stock. I have never done anything exhaust related to a car so I have no idea where to start. Would anyone be able to give me suggestions or point me in the right direction? Ideally I don't want to spend a crazy amount of money. Thank you so much! |
09-25-2020, 05:48 AM | #2 | |
Rep 5,392
One you know the situation, you can take action. A stock 435i exhaust system has three basic components, the downpipe that contains the catalytic converter, the stock midpipe and the axle-back exhaust. Being in California hopefully they did not change out the downpipe with catalytic converters. There are tons of guys in your area who probably have changed out their stock midpipe and stock exhaust and have them just laying around. You can probably buy the used parts very inexpensively. Post on the local Bimmerpost forum and any local Facebook bmw pages that you are looking to buy the stock parts. If you want a little better than stock then ask if anyone has a used M Performance Exhaust. It also came in what was called an MPPK package. You can also call all of the BMW Indy shops and ask if they have any stock midpipes or exhausts. Assuming that you find a stock midpipe which should be easy, there are other aftermarket axle back exhausts available as well. REMUS makes a nice sounding exhaust that's reasonably priced. The best sounding axle-back that I've heard is AWE. Extreme Powerhouse has both of those and other options. Hope this helps! |
conolulu99.00 |
09-25-2020, 05:58 AM | #3 | |
Rep 5,392
09-25-2020, 06:59 PM | #4 | |
Rep 308
09-25-2020, 07:00 PM | #5 |
Rep 308
09-25-2020, 07:19 PM | #6 |
Rep 417
The stock exhaust is actually one long piece, mid-pipe to muffler is in one piece. M-performance exhaust (MPE) is muffler only and you have to cut your original exhaust as indicated in picture 2 and 3 above.
But as John mentioned, check if the downpipe is changed. If the only modification is muffler delete, you can replace it with the stock one or MPE. MPE is slightly deeper than stock and burble becomes more obvious, but still quieter than aftermarket ones. |
conolulu99.00 |
09-25-2020, 08:04 PM | #7 |
Rep 177
If you can jack up the rear of the car and take a few pics of the 'muffler delete'... this forum can definitely help you with the info on what is needed. My personal recommendation would be a quality axleback system like AWE, Remus or BMW's own MPE. The N55 actually sounds pretty decent for a turbo engine when setup correctly.
09-28-2020, 06:14 PM | #8 |
Rep 190,805
REMUS sounds the best in my opinion. It's perfectly balanced with no drone
conolulu99.00 |
10-01-2020, 03:30 AM | #9 | |
Rep 308
Ironically, the more I drive the car, the more I like the sound of it. When I put the car in sport and rev the engine, I think I hear burbles and it's pretty cool. I've never had a car that could do that. The only problem is that the drone is a little much and even my girlfriend complains. Is there a way to keep the aggressive sound but eliminate drone? johnung AK415 Last edited by conolulu; 10-01-2020 at 03:41 AM.. |
10-01-2020, 03:32 AM | #10 |
Rep 308
10-01-2020, 06:53 AM | #11 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
AWE. I have it on my 435i and love it.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
10-01-2020, 08:30 AM | #12 | |
Rep 417
I also attached a picture I took when installing my exhaust, the muffler in the picture is Akrapovic Edit: Looking at the 2nd and 3rd picture you uploaded again, part of the heat shield is significantly darker, seems like carbon deposit. You may also want to check for leaks in that area. Of course you can install a resonator at the same spot to kill two bird with one stone. Last edited by AK415; 10-01-2020 at 08:37 AM.. |
conolulu99.00 |
10-01-2020, 09:10 AM | #13 |
Rep 1,268
I have stock F30 335i - and ive been tempted to chop the muffler off however i've heard reports it will make the car slower if not remapped.
Can anyone confirm this? |
10-01-2020, 10:09 AM | #14 |
Rep 7,606
10-01-2020, 10:10 AM | #15 | |
Rep 7,606
conolulu99.00 |
10-01-2020, 10:32 AM | #16 |
Rep 1,934
+1 on reintroducing a resonator into the exhaust tract. It will definitely remove some of that drone as that is their only purpose. You can find an oem resonator or midpipe, or just get any old resonator installed at an exhaust shop. Maybe install something with the same dimensions ad the oe section, or go a bit bigger. The options are there.
Also +5 for the remus axleback. It sounds good with the stock downpipe.
conolulu99.00 |
10-01-2020, 11:31 AM | #17 |
Rep 190,805
10-02-2020, 01:54 PM | #18 | |
Rep 308
Also thank you so much for the feedback. I really appreciate it! |
10-02-2020, 01:55 PM | #19 | ||
Rep 308
Also will any resonator work? Or does it have to be oem? |
10-02-2020, 01:55 PM | #20 | ||
Rep 1,934
conolulu99.00 |
10-02-2020, 09:36 PM | #21 | |
Rep 417
I don't have much experience on resonator, but like Logicoeur said, any would work. OEM gives you a starting point of what does it sound like out of the factory. I did read about Vibrant being a popular option for BMWs. |
conolulu99.00 |
