05-03-2020, 06:31 PM | #1 |
Rep 28
N55 PWG Overboost after shifting. Help me!
Hi guys! my car is FBO with upgraded turbo (similar to PS2) with GFB DV+ on. we spent lot of time trying to fix this via software tune, but I just figured out that it could be a hardware problem.
has anyone faced it? we can reach boost target 22/23psi on 5thgear but when shift to 6th overboosts to 29/30psi. I m getting crazy with that. sometimes comes DME error: Blow off jammed closed. please help me!!! |
05-03-2020, 06:50 PM | #2 |
Car Hypochondriac
335
Rep 901
It's due to the way GFB has designed the DV+. The extra spring holds the piston mostly closed after letting off. You can remove the extra spring or get a turbosmart DV.
n55david1295.50 |
05-03-2020, 07:16 PM | #3 |
Rep 28
So, you think using stock spring with GFB valve would work? or best think to do is changing it for a turbo smart blow off valve?
05-03-2020, 07:47 PM | #4 |
Rep 758
the GFB DV+ installed with the main spring bleeds pressure slowly instead of all at once. can be a good thing especially with a manual car, I chose not to install it because their was a notice claiming it could cause a CEL. installed without the main spring it will perform exactly like the oem DV except it's a lot stronger. I don't see how installing it with the spring though can lead to overboosting, what turbo do you have installed?
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
n55david1295.50 |
05-03-2020, 08:31 PM | #5 | |
Rep 28
harkes1075.50 |
05-03-2020, 09:25 PM | #6 |
Car Hypochondriac
335
Rep 901
The spring I'm referring to is the one on the left.
I can easily see how this could cause overboost. Throttle shuts between gears, DV barely opens, causing boost to spike rather than being vented quick enough.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
05-04-2020, 04:32 AM | #7 |
Rep 2,354
All PWG cars does this. The throttle closes to compensate so nothing to worry about. I am also running the DV+. Please update us if removing the spring is working.
My car...
(A Dane in China) |
05-06-2020, 12:43 PM | #8 |
Rep 28
i have just removed the spring, and surprise: didnt make any difference hahah. I will now try stock valve setup. What gets me worried is, when overboosting to 30psi, it always comes timming correction ariund 8/9 degrees. lets see the stock one.
05-06-2020, 12:45 PM | #9 |
Rep 28
05-06-2020, 09:58 PM | #10 |
Rep 2,354
Haha I was sceptical but chose not to say anything... Can you share log link with/without the spring?
(A Dane in China) |
05-06-2020, 10:01 PM | #11 |
Rep 2,354
Please share some logs in datazap! I am going through hell getting my PWG PS2 tuned. Working with tuner #3 now to get it done.
(A Dane in China) |
05-07-2020, 08:14 AM | #12 |
Rep 282
https://datazap.me/u/thomas/pureboos...og=1&data=3-19
dont think , you will get rid of it all together . the ewg controller is way faster what would like to see is a datazap of lets say a audi rs3 2.5tfsi , they still have pneumatic wastegate control . maybe its inherent to the bmw design
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
05-07-2020, 12:56 PM | #13 |
Rep 28
will do it when I get home. I was trying now with stock Diverter valve... the results, made me think: should I trow my DV+ on trash can or burn it? hahah car feels much better and stable with stock valve. less overboosting. we will work now on tune and finalize it.
05-07-2020, 01:34 PM | #14 | |
Rep 7,591
05-07-2020, 11:01 PM | #15 | |
Rep 2,354
My experience on the MHD platform (dont get me started with JB4 and BM3 ): Tuner #1 - Gave up working with him after rev 47 Tuner #2 - At rev 30 now. Starting to look decent but not finished Tuner #3 - At rev 10 as test revisions to see if can do it. Will start shortly on a proper map. Never had a mechanical issue influencing the tuning process.
(A Dane in China) |
09-16-2020, 09:09 PM | #16 | |
Rep 2,354
My tune is "finished", however I have had to accept some over/under boost post shift. Hos did it go with your stock DV? Did you compare logs and is it something you want to share?
(A Dane in China) |
09-28-2020, 11:20 AM | #18 |
Rep 7,591
09-28-2020, 12:30 PM | #19 |
Rep 963
right, sorry i meant more specifically to those with PWG and PS2 experiencing overboost. does switching to the one of the turbosmart DV options correct this issue? sounds like those with DV+ are the ones with problems
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
06-20-2023, 09:54 PM | #20 |
Rep 119
Did you guys ever get your car running properly with PS2?
I'm working with a tuner and he has never been able to get rid of drivetrain malfunctions. As I look at the logs he is always overboosting by a few PSI |
06-21-2023, 02:09 PM | #21 |
Rep 7,591
PWG? what tuner? Drivetrain malfunctions for what?
06-24-2023, 06:14 AM | #22 | |
Rep 2,354
THREE MILLION (almost) logs in here if you want to poke around https://datazap.me/u/harkes
(A Dane in China) |
