11-01-2020, 03:11 PM | #1 |
Rep 1,148
Intake manifold removal I'm screwed
Well removing the intake bolts pulled threads from the head on a cold engine
REMOVING them I don't even know wtf to do now |
11-01-2020, 03:23 PM | #4 |
Rep 1,148
Anyone know the stud size
I'm gonna go to a hardware store and see if I can run a stud down there after cleaning the threads up and loctite and use a nut |
11-01-2020, 05:13 PM | #5 |
Rep 1,148
Plot twist
I was able to catch the remaining threads and got it torque down; however gonna order a stud and epoxy/loctite it in place or the like when I have a chance |
11-01-2020, 05:46 PM | #6 |
@_sunbish
282
Rep 611
Pussiwillow521.00 |
11-01-2020, 06:54 PM | #9 |
Rep 1,148
Oil filter housing gasket
You have to remove intake manifold enough to shift it over and out a few inches to get to a tough bolt on the housing. Bolt was stiff the entire time, nothing I could do but pull it at that point; looks to have seized to the threads of the head oddly Not cross threaded, as there's 6 remaining threads or so in the head and bolt still perfect Freak thing I guess Sucks but I'll replace it with a stud like the remaining ones have; and it'll be good Just irritated It's buttoned you, priming the water pump and oil pump as we speak Super easy job, just lame a freak thing happened :/ |
11-01-2020, 07:30 PM | #10 |
Rep 1,288
only thing I can think of is a HeliCoil... Hopefully your fix will hold...
11-01-2020, 07:32 PM | #11 |
Rep 1,148
11-01-2020, 09:02 PM | #13 |
Rep 10,352
Pull the fuse for the injectors.
"Drive more, worry less. "
Pussiwillow521.00 |
12-01-2020, 07:42 PM | #14 | ||
Rep 39
'15 335i x-drive 6MT.
Catless DP, CP, Intake, IC - BM3 STG1 93 ' |
12-01-2020, 10:55 PM | #15 | |||
Rep 1,148
Probably washed the walls down with fuel but it's better than not priming it I guess ha 1k miles she's doing good |
AmuroRay2282.50 |
12-02-2020, 08:06 AM | #17 |
Rep 1,148
