02-24-2020, 12:02 PM | #1 |
Rep 1,010
Changing Final Drive Ratio
I noticed BMW offers the M Performance LSD with 3.23 for FD also 3.15 normal diff.
Has anybody tried changing to a different final drive ratio ?
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 05-10-2022 at 03:54 AM.. |
02-24-2020, 04:32 PM | #2 |
Built Motor F30 340i
403
Rep 257
I'm curious about this. Following.
02-24-2020, 08:10 PM | #3 |
Rep 1,369
You'll need to do some coding, otherwise you'll get all sorts of drive train malfunctions.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
02-24-2020, 09:29 PM | #4 |
Rep 179
To my knowledge the m performance lsd is fully mechanical and requires no coding. Changing the gear ratio in the diff has nothing to do with the computer, it's physically the gear set within the diff that determines the rotation of the axles.
02-24-2020, 09:37 PM | #5 |
Rep 467
I always thought with boosted cars you wanted a longer final gear? These cars, especially with new turbos, etc. top out so quickly, I'd want something with a longer final beat, not shorter. No?
02-24-2020, 10:04 PM | #6 |
Rep 179
02-25-2020, 01:18 AM | #7 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
The manual could do with shorter gearing.
3rd goes to nearly 170kmh and 4th 230kmh. |
B58 parts478.50 SpencerC_6MT197.00 |
02-25-2020, 04:17 AM | #8 |
Rep 1,010
Coding is the easiest part since it's an OEM product the dealer should do it in little time with the installation.
Problem is it's very expensive where I live, anybody know where I can find a good deal on this one ?
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
02-25-2020, 07:36 AM | #9 | ||
Cheapskate
4450
Rep 4,993
The different ratios are offered for different options that came from the factory. You're supposed to buy the LSD that has the same F/D as your OEM diff. The dealer doesn't have an option to program the wrong diff to match your car. Unfortunately the manual already has the shorter gearing of the two. |
B58togo808.50 Duncan140i18.00 |
02-27-2020, 11:11 AM | #10 | |
Rep 198
02-27-2020, 12:22 PM | #11 | ||
Cheapskate
4450
Rep 4,993
If your car came with the 3.23 diff, buy the 3.23 LSD Differential You can't buy the wrong diff and ask them to make it work. If anything it would be more likely that someone on the consumer side would find an exploit to make it work. Not the OEM. |
B58togo808.50 |
02-27-2020, 02:17 PM | #12 | |
Rep 1,239
I remember the carry on i had with a dealer when i coded my mirrors to fold in on long hold of the lock button.... they went and reprogrammed the module as they thought there was something up with the car |
02-28-2020, 07:03 AM | #13 | |
Rep 1,010
I agree but we never heard of an Automatic transmission 340i/440i coming from the factory with the 3.23 Diff.
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- Last edited by IMS-340C; 02-28-2020 at 07:20 AM.. |
02-28-2020, 09:22 AM | #14 |
Cheapskate
4450
Rep 4,993
Maybe I should clarify on what I mean by "option." I don't mean it like the ford mustang where you can order the car with varying gearsets. BMW picked a specific ratio for each combination of engine/transmission/drivetrain. So whatever diff was associated with your car's combination is what you need to order. They created a bolt-in LSD for whatever combination you have, whether it's 4 cyl/6cyl, manual/automatic, etc. That's why in your screenshot it says that the 2.81 is for automatic, and 3.23 is for others (manual). There was also a 3.15 option, i believe for awd models? But they don't make an LSD for x-drive cars.
02-28-2020, 10:32 AM | #15 | |
Rep 1,369
I'm not complaining. I bought an M Performance LSD with less than 100 miles on it for $1300.
kern4174449.50 |
02-28-2020, 05:52 PM | #16 | |
Rep 179
02-28-2020, 06:11 PM | #17 | |
Rep 1,239
02-28-2020, 07:53 PM | #18 | |
Rep 179
Anyways that was a bit off subject for the thread, the OP was asking about M performance diffs, not quaife custom so I'll save that for another time. To my original point though, if you install the correctly geared diff, there is no coding as part.of the process, that's all I was getting at. A diff is a mechanical part and as such does not need to be coded. |
03-01-2020, 03:34 PM | #19 |
Rep 112
Maybe everyone here knows this already but when I tried to order the M-performance LSD on my 340i xdrive I was told you can't install that on an xdrive car. Just throwing that out there.
Follow my build on instagram! @the340iguy
05-08-2022, 10:02 AM | #20 |
Rep 1,010
Anybody changed a rear differential ? is it an easy process ?
05-09-2022, 11:25 PM | #21 |
Rep 9
I just did the diff swap today.
I have a 2019 440i Coupe MANUAL. It came with a 3.23 rear differential and an 0.845 6th gear. I also own a 2019 440i Gran Coupe xDrive with the Auto. The auto came with 2.81 rear diff and a 0.634 8th gear. At 90mph with the GC Auto my RPM is 1950. With the manual at only 80mph it was running 3100 RPM. I don't remember what it is at 90, but I think it was around 4k. I HATE the difference between the two because honestly, I liked getting almost 40mpg in the auto and hated getting only 29mpg in the manual. So I purchased the M-Performance LSD diff in 2.81 (PN: 33108659989) and put it in the manual 440i. Verdict: It's great. Now at 80mph I'm at 2500rpm. It's never going to be as good as the auto since top gear is such a different ratio, but I'm enjoying every gear more. Now, if I lose grip on a hard accel, both rear tires go and the car doesn't do the side to side shimmy that is sometimes terrifying. The car is much more predictable and feels better planted. The swap was straight forward and everything fit. All you need is a 50mm wrench (I purchased one from Harbor Freight) and normal BMW fitment tools (couple torx, 10, 13, 16 and 18mm). Only issue I have discovered: RevMatch is now non-functional. I'm guessing I need to find some way to tell the DME the ratio is different. No fault codes, no lights, no drivetrain malfunction indicators, nothing. Speedo is still correct, as well. |
05-10-2022, 03:02 AM | #22 |
Rep 1,004
great to know and thanks for being the guinea pig. in the n54 world guys were doing this all the time, the mt was 3.08 and the auto was 3.46 and it was a direct swap, there was no such thing as rev matching back then. the mt diff carried a premium price. i am curious what 2nd, 3rd, and 4th are at redline.
IMS-340C394.50 |
