06-11-2023, 01:23 PM | #45 |
Rep 5,392
Yeah, I got that. I was pointing out that if you read New Posts within this application, they all appear to be from the overall generic 3/4 Series forum. It doesn’t indicate if a particular new post was originally posted in a sub forum. Don’t assume that I went into the B58 sub forum and decided to comment. Never went into the B58 sub forum. The post initially appeared like a generic F-30 post to me.
06-11-2023, 03:39 PM | #46 |
Rep 5,392
07-01-2023, 10:00 AM | #47 |
Cheapskate
4450
Rep 4,993
Anyway, someone tell me why I should by the lsd i bought for my manual 440i (3.23) and install it on my auto 340i (2.81)
I understand that manual swap is easy and just disables rev matching, but putting a manual LSD on an auto sounds like a more complicated task. Normally I wouldn't shy away from potentially weeks of development and testing but I don't have that sort of time this go around I'm tempted to just sell it and by the auto version for an easier time all around. |
07-02-2023, 08:48 PM | #48 | |
Rep 383
I can’t imagine it’s different for the LCI cars. |
07-03-2023, 07:54 AM | #49 | |
Cheapskate
4450
Rep 4,993
From my research everything bolts up. But it requires adjustments to the DME and TCU for it to work without errors. I think I'm going to try it |
07-04-2023, 04:20 AM | #50 |
Rep 1,010
Would be great if you can compare Dragy 100-200 or 60-130 for both diffs.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
kern4174449.50 |
07-16-2023, 03:04 AM | #52 |
Rep 239
Drives: '17 M240i 6MT
M240i 6MT 3.08 -> 3.46
Thought I should add my experience in here, since it's relevant. I swapped the stock 3.08 open diff in my M240i to a Diffsonline 3.46 Wavetrac, and have since put over 10k miles on it.
The car does not like it. Every time I've started this car for the past year, it's in limp mode. Eventually the drivetrain malfunction warning stopped popping up, but the car always limits itself to 100nm of torque. After digging through codes, I discovered that it's throwing codes for clutch damage. In other words, the car is seeing higher RPM than expected in-gear, seeing that I'm off the clutch pedal, and assuming the clutch is cooked. The trick I've discovered is to accelerate up to about 15mph, let off the gas for about 3 seconds and let it decelerate in 2nd. The car seems to "learn" that the higher RPM isn't due to clutch failure, and drives completely normally until the next time the ignition is turned off. However, this seems to be the only issue. If the e-LSD is wreaking havoc in the background, I haven't noticed. Cruise control is just fine, the speedometer is unchanged. I don't know about auto rev-match, since I did some Bimmercode fuckery a long time ago to permanently disable it, but I assume that would go out the window. |
07-17-2023, 02:29 AM | #53 |
Rep 239
Yes, it felt noticably faster. The axle ratio is 12.3% shorter, so the same engine output equals 12.3% more power to the wheels. If you go off the rated 335hp number, it's roughly equivalent to the engine now producing 376hp. Of course, the downsides are ever-present. You reach redline sooner in each gear, especially noticable above 3rd, and turn about 300 RPM higher at highway speed in 6th.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
IMS-340C394.50 |
07-17-2023, 12:43 PM | #54 |
Rep 576
I can’t comment on the 6-speed, but I do feel like the 8-speed paired with a higher hp output could benefit from a shorter final drive. I feel the OEM final drive ratio for the 8-speed does suit the stock turbo well.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
07-20-2023, 04:09 PM | #55 | |
Cheapskate
4450
Rep 4,993
I was thinking the opposite. Shorter for stock turbo. |
SpencerC_6MT197.00 |
07-21-2023, 07:38 AM | #56 |
Rep 576
I used the wrong terminology, what I meant to say was a lower gear ratio not shorter. I think for stock turbo, perhaps a shorter gear would be better but I think the stock ratio is good. But I feel like the shorter gear ratio would be the opposite of beneficial with a increased power output especially with a big turbo.
current
07-23-2023, 07:27 PM | #57 | |
Rep 239
By contrast, the shorter ratio in my car comes with more benefits (and compromise). When stock, 1st topped out at 40mph, 2nd at 70, 3rd at 110, 4th at 150. The 1-4 shifts cause a huge drop in RPM, but the 4-6 are very close together. changing 3rd gear from topping out at 110mph to 95mph made driving more enjoyable, purely because I could wind out 3rd in an everyday onramp pull. I can even top out 4th (125 vs 150mph) without being on a dark highway at 1:00a. Of course, I turn 3300 revs at 80mph on the highway now. If only BMW had followed in Porsche/Chevy's footsteps and given us a 7th gear... |
07-23-2023, 08:50 PM | #58 | |
Rep 576
current
07-24-2023, 03:32 PM | #59 | |
Rep 1,454
Basically, BMW could've geared the manual better, even with just 6 speeds, but I get it.
2022 CT4-V Blackwing 6-speed
07-25-2023, 10:01 AM | #60 |
Cheapskate
4450
Rep 4,993
Usually the optimal gearing will have you staying at or below your 1:1 gear in whatever your preferred metric is. So in an Auto, you shouldn't have to shift past 6th in a quarter mile, 60-130, etc. The 8 speed can do 200mph lol. On a stock turbo I could see shorter gears giving you more acceleration without having to go into overdrive gears where the gains aren't worth it. Once you have a bigger turbo, then taller gears make sense for both traction and keeping the cars gearing in power.
McBobby Jr212.00 |
09-14-2023, 09:55 PM | #61 |
Rep 1,693
Where can I find this? I thought I had a pretty good look.
I changed diffs from 2.81 to 3.38 in my F25 X3 30d. I flashed the ECU and DDE with all known references to final drive ratio after comparing ROMs against other vehicles ROMs known to have a different diff ratio. I still get 2 faults from the EGS (Auto TCM), 420474 and 420611 for non-permissible deviation between vehicle speed and output shaft speed. I'll keep investigating and go over the differences between ROMs over the next few days. |
09-17-2023, 02:27 AM | #62 |
Rep 1,693
Found it.
It works! 2.81 > 3.38 and no faults after the relearn |
09-24-2023, 06:35 AM | #63 | |
Cheapskate
4450
Rep 4,993
I know you can drive the car, let it throw codes, then use those codes to find the functions. But I'm not sure how to find it natively. |
01-07-2024, 07:14 PM | #66 |
Rep 239
I don't have ISTA, but I recently bought ProTool, which supposedly has most the same capability. Where did you find this under? I'm going to see if I can work it out to cure the "clutch slip" codes.
mike082802114.00 |
