01-22-2024, 03:44 PM | #1 |
Rep 26
Why doesn't MHD have a 91 Stage 2 HPFP like BM3's 91 Stage 2+?
Pardon me if I'm not well-versed in tuning knowledge, but I see that BM3 has a stage 2+ OTS for 91 octane, and was curious why MHD doesn't provide a similar offering. According to the PTF website, their stage 2+ on 91 offers 13% more horsepower and 30% more torque over stock compared to their stage 2 tune. If this is possible, why wouldn't MHD be able to map something similar to take advantage of a stronger HPFP? In another thread it's mentioned it is because at 91 you're octane limited as opposed to flow limited, but why is that not an issue for the BM3 map? I thought the gen 2 b58 could make more power on 91 than the gen 1 b58 because the HPFP was the limiting factor, but it seems I'm wrong. Anyone with the technical knowledge able to explain it? I was hoping I could get more power out of my TU pump until I get a flexfuel kit for my car.
01-22-2024, 03:56 PM | #2 |
Rep 1,454
Okay a couple of things:
1. You live in California. You have the worst gas in the country, along with Arizona and Nevada. You were never going to make more power on any of the 91 maps. They make specific maps for your state (ACN). 2. You can run the Stage 2+ E30 map to take advantage of your TU pump. You don't need a flex fuel kit. Target E35 since you're mixing with crappy Cali 91 and take a log to verify. Should be much faster and you'll enjoy the newfound power. For the technical tuning stuff, that I don't know. 91 does limit how much timing you can run. BM3 may be increasing boost by a decent amount to make up for it, and more boost = more air, more air = more fuel. The more fuel part is related to fuel capacity, where the TU pump would come into play. Again, just a guess.
2022 CT4-V Blackwing 6-speed
01-22-2024, 04:39 PM | #3 | |
Rep 26
01-22-2024, 05:19 PM | #4 | |
Rep 328
01-22-2024, 10:19 PM | #5 | |
Rep 1,454
Ivilla035114.00 |
01-27-2024, 08:33 PM | #6 | |
Rep 765
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
02-01-2024, 04:12 PM | #7 | |
Rep 2,639
BM3 is based out of Toronto/Canada, so their OTS maps are based on NA fuel. I currently run their Stage 2+ 91 MM OTS, and i put it on the dyno and it made 433AWHP/521AWTQ, it ran 11.49@119mph on dragy as well. This was using NS piss 91 oct (our fuel is literally in competition worst than california,nevada,arizona gas quality)
02-05-2024, 11:38 AM | #8 | |
Rep 1,457
Oh trust me our fuel isn't any better in Cali. I can put a few gallons of E and get the entire gas station to piss inside my tank until it fills up and have better octane than what they give us at the pump. They're so concerned about emissions, but give us garbage that doesn't burn clean. |
