02-01-2024, 06:51 PM | #2 |
Rep 1,457
blacksapphire440i
2024 X3 M40i
2014 BMW M5 |
blacksapphire440i303.00 mg7113.00 |
02-01-2024, 08:16 PM | #6 | |
Novice
303
Rep 695
https://youtube.com/shorts/wMJvC3l2_...PVDJw8yO27-2HU https://youtube.com/shorts/KeBAihdC9...5CoKd0cgGMxjIT https://youtube.com/shorts/Uf6pZiU8a...jUl8hxJb8GAIrL https://youtube.com/shorts/MXOoMl7IS...wIoU9gDxv6rV3O |
02-01-2024, 08:17 PM | #7 | |
Rep 92
02-01-2024, 08:42 PM | #8 |
Rep 92
02-02-2024, 11:36 AM | #9 |
Rep 190,807
Once you get it, please share your feedback
02-02-2024, 11:43 AM | #10 |
Rep 92
I will for sure. If/when I get a 340 I’ll make a thread reviewing and discussing my progress. Just depends on if I can keep up with the payments on my golf and then the plan is to sell it and use it towards the 340
02-05-2024, 07:48 PM | #12 |
Rep 1,791
02-05-2024, 11:13 PM | #15 |
Rep 92
So I was looking around and I found you can just get the mppsk muffler (basically and axel back). If I’m looking at it right it only requires an additional purchase of the wiring harness.
This got me thinking, if I get a 5in dp could I just run 5in all the way back to the mppsk “axel back”? Note this would be a custom fabrication mid section. The idea in mind is 5in pipe from dp to muffler with a about 6in length section change from 5in to the oem 3.3 in or whatever. Links for the mppsk- “Axelback” https://www.getbmwparts.com/oem-part...b3J5IFBhZ2U%3D Wiring harness https://www.getbmwparts.com/oem-part...er-18302414899 |
PeteyF3636.00 |
02-07-2024, 07:38 AM | #16 |
Rep 3,877
The MPPSK exhaust has a larger diameter pipe than the stock exhaust! Don't remember what the diameter was though (3" instead of 2,6" I read somewhere now after a quick search, but uncertain). So bear that in mind if you are planning customisation.
And yes, for the electrical part you will need a new wiring harness for the valves to be controllable.
02-07-2024, 08:21 AM | #17 | |
Rep 92
02-07-2024, 08:28 AM | #18 |
Rep 3,877
It is larger diameter than the stock one for the entire length, from cat to muffler.
I understand what you are thinking of doing, just not sure why... If it was me, I would just buy the entire MPPSK exhaust (which again is already larger than the stock) and move on to other problems in my life than putting together an exhaust midpipe myself You can put a 7" pipe probably, but what good does it do if you have a bottle-neck down the line.... The MPPSK is very well dimensioned, even for a tuned B58... You will not gain anything from going larger, especially not if just the mid-section.
02-07-2024, 10:05 AM | #19 | |
Rep 92
02-07-2024, 11:08 AM | #20 |
Rep 92
I guess my main question is this- would having my exhaust be 5in from the turbo and reduced at the muffler to 3in be too big and the gasses not being able to escape? If it’s not too big would this deepen the sound?
Now you may ask why. Because I want to make the car unique to me. If successful hopefully will inspire more variety of exhaust systems for example how go tank is very popular for their f1 car inspired svj exhaust. |
02-07-2024, 02:40 PM | #21 |
Rep 3,877
There is only one way to find out. But even if you do it - how would you know whether it is deepER than full MPPSK without having a datum...
