02-07-2024, 12:26 PM | #1 |
Rep 190,807
ARM Motorsports B58 Intake + Inlet **NEW PRODUCT**
ARM Motorsports B58 INTAKE - 240I 340I 440I
HIGHLIGHTS • Increased 3.75" Diameter • Improved Airflow • Optional ARM Clear Cover • Compatible with OEM or ARM Turbo Inlet PROFILE The ARM B58 Intake isn't your standard lookalike B58 intake, this has been designed with upgraded 3.75" piping throughout, making it the largest B58 intake available. Combine the ARM B58 Intake with the ARM B58 Turbo Inlet to give your B58 a complete induction solution capable of supporting the most demanding B58 builds! ONSTRUCTION The ARM B58 Intake utilizes an inverted filter design which gives it a massive 186 cubic inches of surface area. Paired with a multimedia filter material which allows for superb airflow while providing impressive filtration and you have a combination that can take your B58 build wherever you want it to go. The filter in the ARM B58 Intake is protected from excessive engine heat by the aluminum heat shield surrounding it. This heat shield comes standard with the powder coated black aluminum cover, or the optional ARM clear cover. Both options look right at home in the B58's engine bay. The ARM B58 MAF pipe is connected to the B58 inlet via the 3.75" 6-layer reinforced silicone coupler. The ARM B58 Intake is designed to connect to either the OEM turbo inlet or for maximum airflow the ARM B58 Turbo Inlet. IN THE BOX • 1x ARM B58 Air Filter • 1x ARM B58 Heat Shield • 1x ARM B58 Heat Shield Aluminum Cover • 5x Heat Shield Cover Screws and Washers • 1x Heat Shield Securing Nut • 1x ARM B58 MAF Pipe • 1x ARM B58 Silicone Coupler • 4x ARM Clamps FITMENT GUIDE The ARM B58 Intake is for Gen 1 B58 engines only ARM Motorsports B58 TURBO INLET - 240I 340I 440I F-SERIES GEN 1 HIGHLIGHTS • 25% Larger Than OEM • Increased Airflow • 6-Layer Reinforced High-Temp Silicone • CNC Machined Adapters PROFILE The ARM B58 Turbo Inlet improves airflow to the B58's turbo by increasing the diameter on the turbo inlet by a massive 25%. Where the ARM B58 Turbo Inlet is greatly improved over the OEM inlets and many other aftermarket inlets is at the turbo snout connection. The ARM B58 Inlet has an inside diameter of 2.5" at the connection to the turbo snout, compared to the OEM inlet which is only 2". Also, by removing the sound mufflers, turbulent airflow is smoothed out, allowing it to enter the compressor turbine more uniformly. The result is faster turbo spool, improved throttle response, and increased power and torque. The ARM B58 Turbo Inlet comes complete with all of the hardware necessary to reconnect the OEM fittings. CONSTRUCTION The ARM B58 Turbo Inlet starts at the turbo with a CNC machined fitting which utilizes the OEM O-ring to seal, and C-clip to secure at the B58's turbo snout. This is where the ARM B58 Inlet body connects to the turbo fitting. The ARM B58 Inlet body is made of 6-layer reinforced high-temperature silicone, and it is constructed to allow for reinstallation of all the OEM fittings he ARM B58 Inlet Body transitions to 3.75" ID where the included joining adapter can be used to connect either the OEM intake or the ARM B58 Intake which maintains a 3.75" diameter all the way to the air filter. IN THE BOX • ARM Turbo Inlet Body • ARM Turbo Snout Adapter • ARM Intake Adapter • ARM PCV Adapter • 5x Clamps FITMENT GUIDE The ARM B58 Turbo Inlet is for Gen 1 B58 engines only
