BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > UK - Off Topic > Formatting USB stick for BMW map update
      11-27-2017, 07:43 AM   #1
JD6
Drives: F30 335d MS+ ACS springs MPS4S
I keep getting this message on my PC:
The USB device selected has been formatted using the wrong file system. Please format it using a FAT32 file system. (FILES0069)
I am using a 64GB USB 3.0 stick, which I have previously used for the 2017-1 map update. When I try and reformat the stick my Windows 10 PC gives me the choice:
File System: exFAT / NTFS (I choose exFAT)
Allocation Unit Size: quite a few choices here, but 128kb is the default - I have tried 128kB and 32kB and still get the same warning message.
Any ideas please?
      11-27-2017, 07:48 AM   #2
Sasquartch
Drives: 328i Luxury auto
The error message is telling you the problem.
You need to format FAT32, not exFAT
You will probably need to use Disk Manager to partition the stick into two separate 32GB partitions. You should then be able to format FAT32. I think FAT32 has a 32GB limit
JD62171.50
      11-27-2017, 08:47 AM   #3
Ridg
Drives: F31 330d
your best bet is something like the HP usb format tool
http://www.softpedia.com/get/System/...mat-Tool.shtml
JD62171.50
      11-27-2017, 09:43 AM   #4
allachie9
Grumpy Old Man
allachie9's Avatar
Scotland
982
Drives: like Miss Daisy
I've just had exactly the same issue myself today.
Downloaded this - EaseUS Partition Manager FREE - from here
https://www.easeus.com/partition-mas...rmat-tool.html
and it worked perfectly.
Alan
JD62171.50
      11-27-2017, 12:01 PM   #5
Cilonen
Cilonen's Avatar
Drives: 2016 F11 530d Luxury
Assuming windows:
Open Command Prompt (type "cmd" in search or run box)
At the prompt, type "format /FS:FAT32 X:" Replace the letter X with the drive letter for the external device you wish to format and hit Enter
No need for downloads/tools - it's all there in the OS
JD62171.50
      11-27-2017, 12:24 PM   #6
JD6
Originally Posted by Cilonen View Post
Assuming windows:
That's good to know, cheers.
You would have thought that they could have given that as an option when I right clicked format, instead of just exFAT / NTFS
      12-28-2017, 04:09 AM   #7
yustashouston
Drives: BMW 320i
The app did allow me to create the 90G FAT32 drive, but somehow this drive was still not acceptable to Update Manager.
Non-Compatible medium (file system)
The selected folder is not suitable for unpacking the map material. Please select another folder to unpack the map material. (UNZIP0077)
I am only partitioning part of the disk, the rest is in NTFS. Could be the reason.
I am surprised more people are not frustrated by this. Win95 DOS programs were more intelligent than this piece of software.
      10-18-2018, 04:34 PM   #8
Mahinda
Drives: BMW 320d SE Touring
Great tip -- I happened to have EaseUS on my system anyway and it seems to be working.
Of course, first I had to track down something that'd hold over 32GB. Eventually found a MicroSD card in my camera that I had to backup and format, after finding a SD-to-USB adapter as my new(ish) laptop doesn't have an SD card slot.
BMW Download Manager is currently unzipping with about as much speed as a 1982 Lada. And not one of the nice ones. I might actually be able to try it in the car sometime next month!
I'm still in the all excited stage, having picked up my shiny new (well, four year old) F31 just two days ago.
allachie9982.00
      10-19-2018, 12:47 AM   #9
aquazi
Drives: 67 435d coupe
There is a far easier way....
As long as you have one fat partition big enough to hold it use a zip tool to manually extract it.
I have used my 500gb external hard drive (powered by usb) with a single 40gb fat partition.
Got the same error as the OP.
Found the folder the bmw tool downloaded it too - somewhere like - local user/app data/ bmw.
Its actually a zip file so manually unpacked it to my drive and the car picked it up fine.
Tjeez0.00
      10-19-2018, 04:05 AM   #10
djcowlin
djcowlin's Avatar
Drives: M140i Shadow Edition
Same problem with MacOS - I have to retrieve the downloaded .zip file from my temporary items folder and manually unzip that, then copy across to the (correctly formatted!) USB drive.
Hopeless.
M140i Shadow Edition | EB II
Gone: 2016 F31 340i | EB II | Black Dakota/blue stitching | M Sport Plus | Adaptive suspension | Icon LED lights | Interior comfort pack | Pro Plus Media | Electric seats
2016 High Up! 75PS | Red
      10-19-2018, 07:14 AM   #11
goodbyalfa
King of the North (living in the east...)
goodbyalfa's Avatar
Drives: 440i GC M Sport +
I had no issues just allowing windows to format a new 64Gb drive however it wanted.
Used BMW download manager to transfer the files, and boom, all done. Worked straight away as soon as I plugged it into the car.
FAT 32 is not compatible as it can't recognize the data >32Gb I believe....
2018 440i GC in MG
MS plus pack others etc....
Previously: 2015 330D F30 MSport EBII
Plus pack, Pro Media, Visibility pack, comfort pack.
      12-09-2018, 05:24 AM   #12
Rune
Drives: BMW 430
Kan inte spara ner kartfil på FAT32 formatterad USB minne
Har testat det mesta som skrivits i denna kolumn utan att lyckas
Har testat att formatera USB minnet till alla FAT32 system (cluster 2kb till 64kb) som man kan hitta men får alltid samma fel varje gång. "Fel filsystem".
Har checkat USB minnet och programmen säger att minnet är formaterat till FAT32. Men det kommer ändå ett felmeddelande.
Har testat med både 32 och 128Gb USB minne. 128GB minnet har jag även testat att dela upp i 2 partioner där den mindre var 32Gb vilket blev tillräckligt för kartan men icke..
Har testat med program från EaseUS partion och MiniAide Fat32 Format.
Kan inte spara ner kartfilen. Några tips ?
      12-09-2018, 05:37 AM   #13
JD6
Har testat att formatera USB minnet med flera olika program till alla FAT32 system som man kan hitta men får alltid samma fel varje gång. "Fel filsystem".
Jag använde "EaseUS Partition Master" för att formatera en 64 GB USB-stick till FAT32 och det fungerade bra med BMWs system
Kanske är 128 GB USB-stick problemet?
      12-09-2018, 05:17 PM   #14
Ajs_435d
Ajs_435d's Avatar
291
Drives: 435d m sport m performance
The new updates are greater than 32g what format/size are people using who acquire files not from bmw?
      12-09-2018, 06:24 PM   #15
ian332isport
ian332isport's Avatar
Drives: F31 340i Shadow Edition
I updated mine today to Evo 2018-4. Used a 64Gb stick that I formatted to Fat32 with EaseUS. Don’t recall the update file size, but the car was happy.
      12-10-2018, 03:00 AM   #16
aquazi
FAT32 can be used on drives larger than 32GB - the only limitation is having a single file greater than 4GB - which should be ok for the map update.
Just format the disk in FAT32 and then unzip the contents (from wherever you got them!) to the usb key and you'll be ready to go!!
      12-10-2018, 10:32 AM   #17
NanasBack
Drives: EB 335 oil burner
Yes. But i think youll find the 64gb drive you have formatted with fat32 has created a drive that is now only 32gb.
Use exFat32 to format above anything above 32gb for the car.
You can then manually extract the zip files to it.
That’s how it worked for me.
      01-08-2019, 09:28 AM   #18
philisme
Belgium
43
Drives: BMW 1M Coupe + M2 + 330e
2016 BMW 330e  [0.00]
2012 BMW 1M coupe  [0.00]
2017 BMW M2  [0.00]
When I plug my USB stick into the car (armrest or the port located on the panel below the AC control panel) nothing happen (the update screen should pop up in theory).
And I can't find a way to start/force the update in the iDrive.
Car : 2016 BMW 330e F30 with NBTevo
USB stick: Samsung 64Gb Fit Plus
Maps download and saved on the USB stick using the BMW software "Download manager"
I formatted the USB stick in FAT32 with my MacBook.
Could someone help me ?
BMW 1M Coupe - AW - 2012
BMW M2 DCT - BSM - 2017
BMW 330e iPerformance - GSM - 2016
      01-08-2019, 09:47 AM   #19
AlwynMike
Drives: F36 440i GC. E91 335d gone.
My 64Gb stick was formatted to FAT32 in Windows (Command line)
With the file unzipped, you should hopefully have
4 files on the root of the drive
1x config
3 x NBTEvo_ECE..... etc
2 directories (or folders if you prefer - I am a DOS Dinosaur!)
1 directory named 1 with 8 sub directories
1 directory named FSC with one file in it.
Check to see if all unzipped properly.
My 2018-4 download was 30.4Gb on the stick
HTH
      01-08-2019, 10:29 AM   #20
Bill10
Drives: F31 330d M-Sport 2012
When you format USB stick with a MacBook it creates additional files. Someone told me you need to delete those files. I put the USB stick in a windows machine and deleted those files and had no problem installing maps to the car. You could try that.
      01-08-2019, 11:49 AM   #21
philisme
Belgium
43
2017 BMW M2  [0.00]
I just deleted the "hidden files" in order to have exactly the files described by AlwynMike but it's still not working.
I'll try with a SD card in a USB-SD adapter
      01-08-2019, 02:39 PM   #22
TiredGeek
Fat Old Git
TiredGeek's Avatar
156
Drives: 335dx F31 Shadow EB
I just use a little program to format my 64gb USB stick and it works perfectly in the car...
https://www.google.co.uk/url?sa=t&rc...jk8SVB9YCZhNYg
It's hilarious just how slow the BMW download manager is at putting the files onto a USB 3 drive though
The doctors said it's OK to listen to the voices..... just don't do what they tell me
