BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F32 Equivilant of service bulletin SI B26 02 14??
proTUNING Freaks
      01-24-2019, 12:46 PM   #1
jrp73
Drives: E92 330D
Hi guys - by any chance do we have any BMW techs on here? Or does anyone happen to know if there is an f32 equivalent of service bulletin "SI B26 02 14" which is for F8x 👍
This bulletin was for the ebrake cable housing rattling against the driveshaft, the service bulletin is for f8x but i have the same issue on my f32...
      01-24-2019, 03:28 PM   #2
supermarket
Drives: 2018 340xi, 1996 328iS
I don’t think so. But there isn’t much of interest in that bulletin. It basically says “bend the tube to assure 10mm clearance between it and the driveshaft.” Were you hoping for a TSB number to get an easy warranty fix?
Early F8x cars had a carbon fiber driveshaft which had a larger diameter than the steel one in your F32. The smaller diameter on the non-M cars makes it more likely that adequate clearance to the parking brake cable tube is maintained, and less likely that this problem will be experienced.
If you are indeed experiencing it, it’ll probably be obvious from scrape marks on the driveshaft, and the bend-it fix ought to be obvious as well.
(TSB attached for reference, even though you may have seen it already and it’s not exactly what you’re asking for.)
