01-29-2017, 05:35 AM | #1 |
Rep 32,881
I thought I'd give this a DIY thread as I'm so impressed with the results! I will never get a diamond cut wheel refurbed again.
I used Halfords emery paper kit, first the medium grade and then the fine, always going in the same direction, until you can't see the damage anymore (if there's some really deep nicks then you might just have to reduce their visual appearance). You then want to rub down the repaired area and a couple of inches around it with 800 grit wet & dry so you can blend the new lacquer in with the old. Clean thoroughly with 70% IPA before spray lacquering with alloy wheel lacquer, I used the E Tech one on Amazon. First do a light 'tack' coat, then build up around 3 more coats every 15 minutes then leave for at least 24-48 hours to fully dry before wet sanding with 2000 then 3000 grit and finally buff to a shine with Meguiars Ultimate Compound. Leave at least a week before sealing, so all the gases can escape. Temperature is also important, you want the wheel and spray can to be at least 20°C throughout the spraying and at least a couple of hours into the drying process. If you look closely you can see where the repaired area is a slightly different colour, but you would have to be looking for it. Before and after: [img]https://s14.postimg.cc/kxpmf3su9/IMG_2286.jpg[/img] [img]https://s14.postimg.cc/6fsf741j5/IMG_2287.jpg[/img] free upload pictures Last edited by teaston; 07-04-2018 at 06:22 PM.. |
UKF302524.00 jbeer154.50 rossm285.50 M40CCA1437.00 MattRST109.50 MashinBenzin8454.50 Soul_Glo13347.00 RichardM133.00 Tribalpinoy91193.00 neilr45.50 B58_Touring875.50 SynTom48.00 Pequin230.00 nikhildj5.50 JayR328i38.00 |
01-29-2017, 05:46 AM | #5 |
Rep 32,881
01-29-2017, 08:51 AM | #6 |
Rep 1,696
Good job! Did you take the wheel and tyre off for the repair?
I did something similar recently with very fine wet & dry (wheel and tyre still on) to remove a small nick but I haven't polished it or lacquered it which has left a flat spot. It looks much better than before but dosen't look as good as your repair. I think I'll have another go when the weather gets a little better. |
teaston10994.50 |
01-29-2017, 09:38 AM | #7 | |
Rep 32,881
01-29-2017, 02:47 PM | #9 |
Rep 63
Was the wheel lacquer the spray can type? Did you lacquer the whole wheel or just the smoothed/polished section? Keen to give this a go on my summers while they're off the car
01-29-2017, 03:04 PM | #10 | |
Rep 32,881
Just lacquered the repaired area, but obviously it overlapped on to the unrepaired areas. |
01-29-2017, 05:14 PM | #13 |
Rep 1,338
Drives: 2014 F30 320D X-Drive
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
01-29-2017, 05:44 PM | #15 | |
Rep 32,881
photo hosting |
01-29-2017, 05:53 PM | #16 |
Rep 602
Good job Tim, but not sure you'd get the same results with a deeper scuff?
Still saved you some money and you've shared another good fix post
Past BMW's: 2017 G30 530d MSport, 2015 F30 330d MSport, 2013 F10 520d MSport, 2009 E60 530d MSport, 2001 E46 330i MSport, 2002 E39 520i MSport
teaston10994.50 |
01-30-2017, 09:43 AM | #20 |
Rep 13,043
Drives: BMW M340I G20
I've done a couple of my own repairs on machine polished wheels. The problem has never been the finish. but finding a decent clear coat that's hard enough. When I've had them done in the past by smart repair outfits. They always add Rocket hardener to the clear coat.The normal stuff available from motor stores ain't up to much.
Current car.M240i. Previous.MINI JCW. E92 325i. 435d M235i.M135i. 635d Coupe, E92 M3 manual, E92 M3 DCT Competition Pack. E92 335i, Porsche Cayman S Gen2, 135i Coupe. E92 320d, MK5 R32. MK5 Golf GTi,MK5 Golf GT-TDI,E46 318Ci. |
01-30-2017, 10:38 AM | #21 | |
Rep 32,881
01-30-2017, 12:19 PM | #22 |
Rep 7,032
Drives: 335xd Msport +
That's a pretty decent job there dude.
I'll bring one of my tyres round for you to do your magic on Ps before any smart Alec says it should be rim and not tyre - just think about it
