09-09-2019, 10:06 AM | #1 |
Rep 5,392
Looking for opinions on upgrading to a Go Fast Bits DV+ with an N55 running BootMod3 EWG Stage2 93 Octane with the stock turbo. I don't expect to ever upgrade the stock turbo due to the huge cost of parts & labor. I'm very happy with this current setup in my daily driver.
I have the impression that upgrading to a DV+ will get the jump on a potential stock diverter valve failure, and also provide better control over intake pressure. Any opinions are appreciated. Thanks in advance. UPDATE: After much research I installed a Turbosmart N55 Plumb Back (quieter) model which is a complete swap unlike the DV+ that reuses some of your old DV parts. I couldn't be happier. In Sport Mode it does a great job of only bleeding off excess boost instead of dumping it all. So no turbo lag & power is right there when I put my foot back down on the gas. Bryan at Kies Motorsports installed it on my car. A link to his video is near the end of this thread. He removed the DV+ and installed the Turbosmart N55 Dual Port model on his car. It vents to atmosphere with a whoosh sound. Hope this helps! |
09-09-2019, 01:24 PM | #2 |
Rep 1,375
I noticed a tad better throttle response after I installed mine. Could have been placebo effect, who knows lol. I have one listed for sale if interested, let me know.
09-09-2019, 01:32 PM | #3 |
Rep 5,392
Do you mean better throttle response at higher revs, or throttle response done low from a standing start or a lower engine revs?
09-09-2019, 01:36 PM | #4 | |
Rep 1,375
09-09-2019, 03:32 PM | #5 |
Rep 426
I noticed your for sale post about 8 hours too late... I would have scooped the FMIC, charge pipe, and DV+.
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
e46m3to335i171.50 |
09-09-2019, 10:36 PM | #6 |
Rep 37
i'd like to know the answer to this too, as I plan on staying stock turbo
F32 2014 435i RWD
Borla Atak full exhaust, Wagner catless DP, aFe intake, VRSF FMIC, VRSF Chargepipe, Bootmod3 stage2 Octane 93 (AGG) BC Racing Coilovers |
MARC20102.00 |
09-10-2019, 09:52 AM | #7 | |
Rep 426
09-10-2019, 04:14 PM | #9 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
Regardless of modifications, the stock DV will start leaking and rob power. & response. Most don't notice because it happens very slowly and you become accustomed to the current power/response.
A good rule of thumb is if you have 50K miles it's time to upgrade. Stage 1-2+ or Upgraded turbo guys definitely want this upgrade. |
09-10-2019, 04:40 PM | #10 | ||
Rep 5,392
BeerHerder250.50 |
09-10-2019, 04:45 PM | #11 | |
Rep 5,392
So if you don't have many miles on your car so your stock DV isn't really worn yet, if you upgrade to a DV+ what change or improvement will you feel from the DV+? |
09-10-2019, 04:57 PM | #12 | |
3441
Rep 79,211
09-10-2019, 05:35 PM | #13 |
Rep 1,288
Is there a video for this?
09-10-2019, 05:42 PM | #14 | ||
Rep 5,392
Pittcrew34.00 |
09-10-2019, 05:58 PM | #15 |
Rep 18
Turbosmart just released an Electronic Plug and Play version of their EM Valve for the N55. They have them available in a Plumb Back Version that recirculates like stock and a Dual Port version that vents to atmosphere. No need to to tear your stock one apart, it's a direct plug and play valve. It sounds great and definitely holds boost better under lighter loads.
EDWYER1674.00 |
09-10-2019, 11:37 PM | #16 | |
Rep 5,392
09-11-2019, 05:29 PM | #19 |
Rep 18
I would definitely upgrade over the stock Pierburg Valve that carries open under low boost conditions. It needs to pressurize in order to hold boost and it has been proven to not hold under low RPM and Light Load conditions. It's also nice to have something that can vent more than stock to keep compressor surge under control especially when running more boost or even a bigger compressor wheel like Pure's.
In all fairness there is really no need for anything if we keep them stock. |
09-11-2019, 08:06 PM | #20 | |
Rep 5,392
UPDATE: I did receive a call back. Sounds like they are in the middle of new product release activities so I'd keep an eye on their website for updated information. |
BeerHerder250.50 |
09-12-2019, 07:12 AM | #21 |
Rep 4,146
I’ll just chime in once more and point out that I googled the Diverter failure and it seems more like a N54/PWG issue. Most OTS and tuner maps aren’t running 18psi on the stock turbo.
I was reading a thread this morning on a turbo inlet - that would be where my money goes. 20hp in the top end would be awesome. https://f87.bimmerpost.com/forums/sh....php?t=1649488 |
09-12-2019, 08:47 AM | #22 | |
Rep 83
I think my DV needs to be upgraded and would rather this if available over the GFB. |
