09-22-2019, 01:23 AM | #1 |
Rep 166
Base stereo added speakers - equaliser?
Hi guys...
Recently bought new mids for the front as well as two tweeters ... I have the base stereo (European version) which means no amplifier or custom equaliser.. There is a noticeable difference in sound however I would like to be able to customise it a bit .. I have two questions here: 1. What do I need to code specifically to change it from Base Stereo to Hifi to enable the equaliser in idrive? 2. Will the system still work properly without an amplifier ? I seem to have read somewhere that if you code hifi or HK for that matter the amplifier is no longer optional but mandatory ... don't know if it's because it disables the headunit amp or what it is ? Thanks in advance to all! |
09-22-2019, 08:26 AM | #2 |
Rep 16,079
You can't code the HU for EQ because the EQ hardware is in the separate amp.
DavidSTryk23.00 |
09-22-2019, 08:44 AM | #3 | |
Rep 2,180
DavidSTryk23.00 |
