11-18-2021, 09:03 PM | #1 |
Rep 3,190
Spark Plug Replacement PSA
Just want to let everyone know that the recommendations we can run spark plugs to 20-30k miles is BS. I ran MHD stage 2+ E40 for 15k miles (not even hard miles, handful of street pulls max) and my plugs were shot. I should have replaced them at 12k miles. I'm running the NGKs from Burger motorsports, stock gap. I started noticing louder exhaust burbles, lurching from a stop, poor on/off throttle response, massive timing drops. Since replacing the plugs this is all gone and back to normal. It was so bad I thought my transmission was going out.
Replace your spark plugs at least every other oil change. They are not special plugs that last longer than E9X plugs. |
11-19-2021, 05:04 AM | #2 |
Rep 282
dont know what you did or what fuel you took but replacing them every oil change is BS aswell . mine are still fine after 30K i run mhd stage 2 aswell
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
11-19-2021, 05:49 AM | #3 |
Rep 844
Yeaaaaaaaa been doing this a while on many cars and platforms and never have I ever had to change my plugs at earlier than 40k intervals even on stage 2 tunes. Not sure what setup your running but I would start checking some stuff if your burning through plugs in 12k
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
11-19-2021, 07:29 AM | #4 | |
Rep 1,597
11-19-2021, 08:24 AM | #5 |
Cheapskate
4455
Rep 4,995
Sounds like something else caused them to fail. Plenty of people go 30-40k on plugs.
11-19-2021, 08:36 AM | #6 |
Rep 3,190
11-19-2021, 08:40 AM | #7 | ||
Rep 3,190
11-19-2021, 08:56 AM | #8 | |||
Rep 5,396
11-19-2021, 10:37 AM | #9 | |||
Rep 844
11-19-2021, 11:17 PM | #10 |
Rep 3,190
11-19-2021, 11:26 PM | #11 |
Rep 3,190
11-21-2021, 12:46 PM | #15 |
Rep 1,372
Started getting miss fires on the original plugs at ~25k and changed them at 26k. Had been on JB4/DP and 93 since 1200 miles. After that, I did them at 45k and again at 63k, along with coils on that last one. Then I grenaded the stock turbo at 64k, so did them again. I like to do them by 20k, because I don't think they have a ton of life left at that point when I'm FBO/e40.
540iSUP704.00 |
11-21-2021, 05:03 PM | #16 |
Rep 3,190
Thanks for that, it did lower the burbles but not fully remove it. Seeing as I was on the stock settings (never changed when I flashed MHD), that would mean everyone with M sport burbles would be blowing through spark plugs if it was the cause.
11-21-2021, 06:03 PM | #17 |
Novice
309
Rep 697
what are m sport burbles?
11-21-2021, 06:11 PM | #18 |
Rep 3,190
11-22-2021, 01:41 PM | #19 |
Novice
309
Rep 697
11-22-2021, 01:51 PM | #20 |
Rep 1,456
Ion know about allat. My 2016 340ix 6-speed was FBO but untuned for 2 years prior to BM3 release. The stock tune was very burbly and would produce gunshots and backfires very loudly with no problem. Maybe that changed with later software revisions, but I thought stock it was absolutely crazy lol. BM3 OTS burbles are actually slightly toned down from my experience.
2022 CT4-V Blackwing 6-speed
12-14-2021, 12:16 PM | #21 |
Rep 5
Mileage seems to vary all over the place for tuned vehicles from 12k-40k. Picked up some OEM plugs from FCP so I won't have to worry about anything other than labor
