11-16-2021, 12:14 AM | #23 |
Rep 1,058
The drain that's located behind the door panel is the culprit. It was a common issue on e90s as well.
I have a post with a video where I commented it somewhere … Water leak-hopefully fixed https://f30.bimmerpost.com/forums/sh....php?t=1643300
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
11-16-2021, 06:59 AM | #24 |
Rep 975
This is a common issue with BMW's period. It's called a vapor barrier and over time, the seal just disintegrates which allows water in.
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
AndrewC198910915.00 |
11-16-2021, 09:32 AM | #25 |
Rep 4
Thanks for the replies, but again I need to state that IT IS NOT COMING IN THROUGH THE DOOR. When I pour water into the driver side drain (corner of windshield), the water somehow gets through the firewall and onto the driver side floor.
11-16-2021, 10:17 AM | #26 | |
Rep 4,550
Drives: 2015 328d xDrive
NYC Bimmer259.50 |
11-27-2021, 09:49 AM | #27 | |
Rep 2
Much appreciated on any reply. Thanks TB |
11-27-2021, 12:10 PM | #28 | ||
Rep 1,641
12-11-2021, 10:00 AM | #29 |
Rep 1
I experienced a very wet passenger side floor after my regular car wash installed a brand new, very high-powered car washing system.
I just want to know from WHERE the water entered!! |
02-24-2024, 11:53 AM | #31 | |
Rep 4
02-25-2024, 08:15 AM | #32 |
Rep 1,756
There are no windshield "seals" on these cars, just cowl and decorative trim. The windshield is sealed to the frame with an adhesive when it is installed. That is what makes it "water tight".
2016 428ix, r, 2018 430iC, 2018 330it
03-19-2024, 03:38 PM | #33 |
BMWLad
1469
Rep 2,393
Drives: 320D M Sport
Just like to open this topic again as I too am having the same issue with my 2013 F30.
Soaking wet drivers side rear footwell, huge puddle of water in the footwell, I have a UK car so this is the right hand side of the car. It’s been raining for the past 3 days continuously so I have been sponging out the water from the footwell for the past 3 days. It’s been raining for the past hour, I’ve just went out and checked and there is a puddle of water yet again. I’m getting really frustrated with this now. Does anyone know what the first course of action would be? Someone mentioned seals or water vapour inside the rear door. Do I really need to take the door card off to try and solve this issue? |
03-19-2024, 03:58 PM | #34 | |
Rep 1,507
03-23-2024, 08:09 AM | #35 |
BMWLad
1469
Rep 2,393
As a bit of an amateur on these things, is the rear door card easy to remove?
03-23-2024, 09:44 AM | #36 |
Rep 1,507
