BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > How to prevent wheel to disc hub corrosion
proTUNING Freaks
      11-27-2021, 07:33 AM   #1
PG325
Drives: BMW e30 325i & f32 435i
I've recently purchased some new BMW alloys, the original set were showing signs of corrosion, especially where the wheel mounts onto the brake disc.
Is there something I can use in between the faces to stop the reaction of metals?
      11-27-2021, 08:07 AM   #2
Craig-SM
Drives: BMW 320d M Sport - F30
Whatever you coat them with is only a temporary fix as they work in very harsh conditions not just from the weather but also effects of braking too with heat, gases and debris that eats away at the coating.
      11-27-2021, 08:24 AM   #3
HighlandPete
Drives: BMW F11 535i Touring
You shouldn't be using anything that acts as a lubricant on the clamping faces. (Neither disc hub face, or wheel mounting face). Any anti-seize grease / compound should only be used on the hub centre spigot.
      11-27-2021, 08:34 AM   #4
martin10chk
Drives: F31 316i, F21 M135i (gone)
This - and its only really there that the corrosion is a problem in any case. Whenever I take the wheels of (switching summer to winter and back) I clean those areas off with a wire brush. They come off a lot easier and cleaner the next time. No grease required here.
      11-27-2021, 08:38 AM   #5
jenshb
Drives: 2016 340i MSport
The only way you could do it is to physically isolate the metallic contact between the dissimilar metals. Check out "galvanic corrosion".
      11-27-2021, 09:18 AM   #6
PG325
It is the hub centre where the old wheels are corroded, this is where I was hoping there was something available to prevent it.
      11-27-2021, 11:58 AM   #7
Ennoch
Drives: F31 335D XDrive
You could slather some marine grease in there, as long as you don't get it on the mounting faces. Clean off what corrosion there is and then apply. It's sticky stuff so lasts pretty well.
