BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Replacing Shockbreaker
      11-19-2021, 11:53 PM   #1
free2d
Drives: F30 335
Hi
My F30 335i stock sedan suspension are giving up soon.
I was wondering my sedan can fit the
Genuine BMW Retrofit Kit Sports Suspensi - 33502320981 for F30 335i.
Can the stock springs be use together with this kit since it does not come with spring?
Must I recode the car?
Thanks.
      11-20-2021, 05:05 AM   #2
SuperLomi
Drives: 2013 335i M-Sport
1) Do you have ECS? This kit does not retain ECS - it is standard hydraulic dampers. So you would need a ECS delete kit and code it out I think.
2) these dampers will over damp the stock springs, even the m-sport, producing a harsh ride. You can buy the kit and springs together. Best place seems to be getbmwparts.com
3) If your car is not an M-Sport, the kit recommends sway bars also (same bars as M-Sport).
If you’re not trying to improve performance, and just need new struts, look into the bilstein b4 or b6. I would probably say b4 for non-m sport, and b6 for m-sport.
      11-20-2021, 05:21 AM   #3
free2d
Drives: F30 335
Mine is M-Adaptive suspension with sensors cables.
I need to replace more than the shock absorber.
According to dealer diagnose, Spring strut, Guide support, spring pad, damper all need to replace. That's why looking at the kit.
      11-20-2021, 05:28 AM   #4
SuperLomi
If you want to retain the adaptive suspension (ECS) this kit will not work.
      11-20-2021, 07:01 AM   #5
free2d
Drives: F30 335
I will ask other mechanic to check again to see whether change only the struts. That will be easier.
