10-13-2021, 09:22 AM | #3 |
Rep 244
10-13-2021, 01:21 PM | #5 |
Rep 16,037
You can see the wire going into the sill.
I didn't want to mess with wires, so ordered a pair of these, with the BMW logo: https://bloomcar.myshopify.com/colle...37911392288964 It's battery powered, so no wires. The light changes colors and flashes as shown in the video. I'm on the fence about that. It uses magnets attached to underside of the door to trigger the internal on/off switch. I found that the distance from the bottom of the door to the sill is too far for the included magnets to work, but a couple of 3/16" thick large magnets from Walmart did the trick. Shipping is from China, which takes about ten days. |
10-13-2021, 01:52 PM | #6 | |
Rep 1,641
10-13-2021, 03:26 PM | #7 |
Rep 16,037
I had the BMW OEM sill lamps. The first one died from water getting in and corroding it after two years, the second one gave up the ghost two weeks ago. That's why I got these. They use a rechargeable battery, using a standard cell phone charger and cable. Every few months you pull them and charge them overnight. They're held onto the sills magnetically, so it's easy to pop them out and put them back in.
10-13-2021, 06:17 PM | #8 |
Rep 107
I got them from Aoonuauto.com you can get any color or multi color they are made to order takes about 3 weeks you can easily tap into your door power for these lights. no magnets or any other nonsense
2014 435i/VRSF CATLESS DP/AWE MIDPIPE&EXHAUST/VRSF CHARGE PIPE/BMS INTERCOOLER/TURBOSMART BOV/INJEN INTAKE/MHD STAGE2+ |
10-13-2021, 06:22 PM | #9 |
Rep 107
Its just 2 wire taps takes 10 min and its like oem. No charging or magnets it fits perfect and you can choose your own logo with the colors flashing or going back and forth just go to the website i mentioned in the last post you will not be disappointed.
10-13-2021, 06:26 PM | #10 |
Rep 107
10-14-2021, 09:10 AM | #11 | |
Rep 75
Same with the Chinese illuminated door sills in this thread, they fail, get water logged and scratch like crazy. Ended up buying OEM battery ones, and they work perfectly, had them 2 years so far with no issues. |
10-14-2021, 12:00 PM | #12 |
Rep 16,037
The OEM are from China as well, and fail they will, sooner or later, as they're not waterproof. The ones I got cost me $55 with shipping, which is just as good as when you order from AliExpress. You can always find coupons, I found them on youtube for the ones I got. There are other sources for the same thing, for instance https://www.carledlogo.com/led-door-...0aAs3QEALw_wcB
chowser512025.00 |
10-14-2021, 04:59 PM | #13 |
Rep 107
ive had these for about 2 months now and they are still perfect. Like anything only time will tell, everything wears out
10-15-2021, 08:39 AM | #16 | |
Rep 1,641
Cheers. |
10-15-2021, 11:22 AM | #17 |
Rep 16,037
After my first one died I opened it up to find corrosion. It was the driver's side, the passenger was still OK, that door is seldom opened, so there was far less opportunity to get water on it. I swapped them, and when I did I sealed up the good one as best I could. It lasted another four years, but when I opened it up the other day it had corroded inside as well.
10-16-2021, 11:16 AM | #18 |
Rep 107
4 years is still a long time though
10-16-2021, 10:23 PM | #20 |
Rep 107
Yeah that's true hopefully mine will last a year at least. That will give me a chance to get a new set with a different logo and light scheme.
11-13-2021, 12:43 PM | #22 |
Rep 268
My oem ones done the same as Billfitz. In the UK climate water ingress is always an issue but my car only does 4k tops a year so the majority of the water was from washing the car. For the cost they are sh1t quality.
