BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode app iOS/Android
proTUNING Freaks
      08-30-2017, 03:16 PM   #111
LMK5
Drives: 2017 330i Imperial Bloo
Originally Posted by dr.roro View Post
Coding success with Bimmercode and Vgate iCar2!
Super easy to get connected and start coding with my iPhone 7 Plus. Expert mode allows you to get everything you want using a cheat sheet for any options not already listed in the app. I did get some warnings/errors (e.g. Lighting and Chassis Stabilization) after coding a few things (even with engine not running), but they went away on their own after turning the ignition off and on, so I'm not too worried. Significantly less work than figuring out E-Sys...
Here's the full list of what I was able to successfully code on my 2015 F32 435i:
Disable iDrive legal disclaimer
Disable camera legal disclaimer
Fold mirrors when locking with keyfob, change delay to 0.2 secs
Unfold mirrors when unlocking with keyfob
Change iDrive startup animation to M logo
Display individual pressure and temperature on TPMS display
Enable Sport Displays (hp/tq)
Turn off radio when driver door is opened
Unlock driver door when ignition off
Enable digital speedometer on instrument cluster
Disable initial seat belt warning
Change seat belt reminder duration to 5 secs
Auto Start-Stop set to off by default
Did I miss anything?
How about having the audio system volume memorize where you left it or at least come up higher than 25%?
      08-31-2017, 07:40 AM   #112
evdok
evdok's Avatar
Drives: 330D M/SPORT xDRIVE INDIVIDUAL
Is it possible to code iPhone mirroring on my late 2013 F30?
Happy Motoring
Evdok
      08-31-2017, 08:24 AM   #113
AudiA4
AudiA4's Avatar
648
Drives: 2022 G01 X3 M40i (Black/Black)
No
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust
2006 E90 330i (Silver) 6MT, Sport
      08-31-2017, 08:37 AM   #114
F30Beast335i
Drives: 2013 f30 n55 335i
Only possible way is with a update of your idrive software .
      08-31-2017, 12:54 PM   #115
AudiA4
AudiA4's Avatar
648
Not possible...Apple CarPlay requires updated hardware.
      08-31-2017, 01:03 PM   #116
Tux
Originally Posted by scostu View Post
Code out ASD!
I have ASD on my 2015 F32 435i?
I was under the impression it wasn't on 435i / 440i. Happy to be proven otherwise
      08-31-2017, 01:19 PM   #117
dr.roro
Drives: 2019 G01 X3
I actually like this feature.
      09-04-2017, 06:08 AM   #118
Kingpin4
Kingpin4's Avatar
Drives: 2018 X3 M40i/2019 M2C
Anyone code rear fogs?
      09-04-2017, 09:15 AM   #119
jmciver
///M SubDriver
jmciver's Avatar
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Shouldn't be an issue using Expert Mode. Once you make the physical modification to the light switch, here is the coding that needs to be done (pulled from another thread):
REM Module
REM -> Mapping_Nebelschlussl_L_output: nsl_l
REM -> Mapping_Nebelschlussl_R_output: nsl_r
FEM_BODY
3060 NSL_Verbaut: verbaut
I did this coding using my laptop a while ago, but I see no reason why it can't be done with the app. Although, it would be nice if the app had a search function, which would make finding the parameters easier as there are a lot of them to sift through....
Edit: I stand corrected, there is the ability to search in Expert Mode - I completely missed it (the search window is along the top of the screen after you open an ECU, similar to other iOS apps). I am really liking this app even more now.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      09-04-2017, 05:11 PM   #120
Kingpin4
Kingpin4's Avatar
Thank you!
I agree.
Search function would be awesome!
      09-04-2017, 10:45 PM   #121
WajahatM
Drives: 2013 AW F30 335i xDrive
Thank you!
I agree.
There is a search function in the app. Just go to the correct module, hit expert mode, then search up the necessary code. I coded my rear fogs using Bimmercode with the code above.
      09-27-2017, 06:26 PM   #122
chums
Drives: 328
I just paid for the unlock, the app is requiring an in app update but when I try to update it never completes. Any idea why?
Edit: oh, this is the Android app.
      10-09-2017, 09:15 PM   #123
ELiTeNeSs
ELiTeNeSs's Avatar
Drives: 2014 BMW 335i
Can you code the sports auto transmission with bimmercode in expert mode? Or is this option only available with esys?
      10-09-2017, 10:22 PM   #124
Shezzy Bear
Drives: '13 F30 328i xDrive
Just saw this on a different thread for a 320d
Originally Posted by kretzu View Post
Hello bimmerz!
This is the correct way to code SPORT+ and SAT.
I own an F30 320ed that came with modern package, so, no sport + mode neither SAT. Keep in mind that I didn't changed VO! Everything worked without changing VO!
This is what you need to code:
>>> For SPORT+ <<<
KOMBI > 300C ECO_FDS > FDS_MENUE_TEXT 1,2,3,4 = menue 3
KOMBI > 300C ECO_FDS > FDS_MENUE_SIGNAL 1,2,3,4 = menue 3
KOMBI > 300C ECO_FDS > FDS_MENUE = menue 3
ICM > 3000 > ICMKOD_B_SPORTLENKUNG = verbaut
>>> For SAT (sport auto trans) <<<
EGS > 3000_Applikation > Sportschalter_alt = aktiv
EGS > 3000_Applikation > Sportschalter = aktiv
If you want, you could also code Launch Control. I didn't code this, yet.
EGS > 3000_Applikation > LC = aktiv
Have fun!
Proof.
I'm not sure if these are the same steps that you or myself (328i) would take to achieve the same results. Give me 20 minutes and I will let you know if anything happens
      10-10-2017, 05:48 AM   #125
gbi
Drives: 318d f31
Hello I have downloaded Bimmercode for Android but I can not find the Expert mode. Is it present only in the iOS version or am I dummy?
      10-10-2017, 07:21 AM   #126
ELiTeNeSs
ELiTeNeSs's Avatar
Anything? Haha
      10-10-2017, 11:03 AM   #127
CaroleBaskin
Big Cat Rescue
CaroleBaskin's Avatar
Drives: '20 M4CS - Lime Rock Grey
This app is f-ing fire. iOS, quick support via email from the app (it attaches your logs)
      10-10-2017, 06:08 PM   #128
Shezzy Bear
Anything? Haha
Sorry about that lmao, I got distracted and was modifying some previously coded stuff until like 1:30 AM. So the sport+ worked (which I expected) but the I could not get the SAT or launch. After some research, it seems as if the sports auto transmission is only available to 2014+ vehicles.
If I remember correctly, this requires one to then VO code FA and change 205 (automatic transmission) to 2TB (SAT). After this you will have access to the EGS module to change the values accordingly.
You can do the EGS changes either way you choose but since you need to VO code those parameters, it just makes sense to do the rest via E-Sys.
ELiTeNeSs196.50
      10-12-2017, 08:08 AM   #129
Auditobimmer42
Drives: M340i
Bimmer code is awesome. So mad I threw money down the drain with Carly. Carly is just fine I guess. But overpriced. And with no expert mode, you are at their mercy to wait for an update for a feature.
      10-12-2017, 12:25 PM   #130
YeaG30
YeaG30's Avatar
Drives: 2017 540i
I sure was hoping that this was going to be possible. E-sys is intimidating to say the least.
2017 540i :: 2006 M3 :: 2012 328i Sport Line (sold)
      10-12-2017, 03:13 PM   #131
ELiTeNeSs
ELiTeNeSs's Avatar
Anyone know what parameter to change the sport gauges raised to the 400hp/tq instead of the 320hp/tq
      10-12-2017, 03:30 PM   #132
Shezzy Bear
I could see how it would be. As a tech lover and programmer, I naturally will go to any means to code my vehicle as much as possible without hesitation. I guess if I brick my car we will have our answer to whether or not that is a good thing lol.
I have a cable coming in tomorrow (too lazy to wait for a cheap China OBDII to make my own) so I guess I'll be the guinea pig. My car is as bare bones as you could imagine: non-M sport, no cold weather package, tech package, navi, comfort access, PDC, nothing. I don't have my hopes set to high, but If I'm able to do it then just about anyone should. In the event that things go well, I will let you guys know if and how the layout of the BimmerCode app changes.
Just remember, at the end of the day no one is breathing down your neck while your coding. As long as you watch any available coding tutorial and/or read the instructions carefully. If you need to rewatch/read the instructions 20 times then so be it. Just take your time and you should be good to go!
