01-20-2022, 05:59 PM | #1 |
Rep 352
First time coding on F series - please help
I recently bought a OBD2 enet cable and a enet to USB c adapter to connect to my android phone.
I plug in all the wires and can see light of the enet cable signalling there is power, and light on the enet to USB c adapter also signalling connection. But when I connect it to my phone and run MHD, Bimmercode or Protocols - I keep getting the message that no cable is detected. Interestingly on Protocols, it reads a connection but says the vehicle is not supported. What am I doing wrong here or is there a suspected fault? |
01-20-2022, 06:01 PM | #2 |
Rep 352
I bought this cable:
https://www.amazon.co.uk/dp/B07B2HZ6...ing=UTF8&psc=1 And this enet to USB c adapter: https://www.amazon.co.uk/dp/B08JGL51...ing=UTF8&psc=1 |
01-22-2022, 12:25 PM | #4 |
Rep 135
I believe the issue is that most Android phone devices dont supply a DHCP address as they have to act as a DHCP server when connecting to the car. Only some samsung devices work from what i read a while ago. If you can set the address as a static one on the phone then this will work but again a lot of android devices dont allow configuring of IP addresses on ethernet set up, limitation of Android im afraid. I ended up getting a bluetooth OBD and use Bimmercode with bluetooth.
01-22-2022, 12:42 PM | #5 | |
AH3 Owner
194
Rep 292
Drives: BMW 335i ActiveHybrid 3
01-22-2022, 09:14 PM | #6 |
Rep 16,054
I use a Veepeak Bluetooth adapter, no worries at all with Bimmercode. With Bimmer-tool Lite I have to go into the phone settings to connect the phone to it first, Bimmercode even does that by itself.
