08-22-2020, 05:30 AM | #1 |
Rep 99
Bushing on Thrust Arms
Hey guys, I got a 2016 BMW 340i xDrive with about 44K miles. (BM3 Stage 2 Tune)
A mechanic recommended me changing my thrust arms because the bushings seems to be going bad. Can I just change the bushings or the entire lower control arm needs to be changed? |
08-22-2020, 09:42 AM | #2 | |
Rep 5,456
Drives: F30
08-22-2020, 04:08 PM | #3 |
Rep 1,649
Personally I would just do the whole arm. The savings in labor pressing them in and out will probably net out with the increased cost of parts. Go with VAC or Turner monoballs for much improved steering response and feel.
johnung4528.00 SomethingBlue10.00 |
08-22-2020, 04:26 PM | #4 |
Rep 99
So go aftermarket for the arms? Or is OEM also recommended when it comes to thrust arms?
08-22-2020, 05:33 PM | #5 | |
Rep 68
If you want to tighten up the steering and have a vast improvement in turn-in feel/response and have the money to spend, look at aftermarket monoball replacements. I just replaced both thrust arms with complete units from VAC with their monoball installed. They run $550 for the pair and are a VAST improvement from the failed stock arms/bushings. |
08-23-2020, 01:50 AM | #6 |
BMW CCA Member
488
Rep 808
+1 Turner, VAC, etc. around $500-ish but man you will wonder what happened (in a good way!) to your car the first time you make a turn.
johnung4528.00 alohasurftoad3078.00 |
08-24-2020, 04:10 AM | #7 | |
Rep 99
08-24-2020, 05:16 AM | #8 | ||
Rep 241
The question is fo you want a luxury-sport vehicle or a spot-luxury vehicle. I would also add that if do this you should replace the LCA bushing as well with a monoball. Similar reasons and benefits in the replacement and i would not recommend having on soft bushing and one firm monoball from a suspension geometry under load perspective. |
08-24-2020, 03:22 PM | #9 | |||
Rep 99
I guess when it comes to a fast sports car as long as I can go fast in a straight line is what really counts. Doubt I will ever track the car. Also, coming from a heavily modded JDM car (Infiniti G37S Coupe) I kinda wanna chill and ride luxury for a while haha Thanks guys for all the great feedback. New to the Bimmer game. |
08-24-2020, 07:24 PM | #10 | ||||
Rep 241
I am sure youll be happy! |
UrbanCarCulture20.00 |
08-26-2020, 10:18 AM | #11 | |||||
Rep 99
08-26-2020, 12:50 PM | #12 |
Rep 894
I replaced mine with the turner motorsports kit and it made a big difference on turn in feel. Greatly reduced that center dead zone in the steering (esp in sport mode) and didnt really notice any increased nvh.
08-26-2020, 02:34 PM | #13 | |
Rep 126
Has anyone done/considered something like this? Last edited by SD Convert; 08-26-2020 at 02:49 PM.. |
08-26-2020, 09:09 PM | #14 |
Rep 241
I went with the F80 TAs and LCAs. I couldnt happier. Turn in and feel are fantastic. However, i certainly get a fair amount of V (vibration). Thats said i am not sensitive to nvh so it works. I am actually waiting of delrin rear subframe bushing install right now along with a wavetrac. More nvh perhaps but i am slowly but surely building my dad wolf in sheeps clothing racecar!
08-27-2020, 08:11 PM | #15 | |
Rep 891
https://www.millway.se/bmw/3-series/f30-f31-f32.html
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
09-03-2020, 05:16 AM | #16 |
Rep 228
Has anyone been in recent contact with VAC? I've reached out twice with no response. COVID issues?? This thread has me itching to upgrade to monoball.
09-03-2020, 11:41 AM | #17 | |
Rep 8,498
Pre-Covid I found that VAC responded promptly to my general enquiry. A few weeks ago I sent a follow-up email asking for pricing and shipping costs to the UK - no response.
AddictedTo///M217.00 |
09-09-2020, 09:54 PM | #18 | ||
Rep 205
Drives: 14 F30 335i xDrive
02-02-2021, 12:27 AM | #19 | |
Rep 1,369
02-02-2021, 06:55 PM | #20 | ||
Rep 891
02-02-2021, 08:18 PM | #21 | ||
Rep 5,392
BMW installed those huge fluid filled bushings in the F3x Upper Control Arms (also called Thrust Arms or Tension Struts) to absorb Noise Vibration and Harshness. But they have excessive clearance which contributes to the complaints about the vagueness of the F3x steering. Installing more solid polypropylene type bushings reduces the clearance but it adds a lot of NVH because they have restricted movement. Monoball bushings solve both problems because they reduce clearance to improve steering while also having unencumbered movement to prevent adding NVH. I have the VAC Monoball Thrust Arms. The steering is now incredibly precise under both acceleration and braking. They did not add NVH to the chassis and cabin occupants. What it does add is road feel transmitted to the driver's hands on the steering wheel. It's a welcome feeling. What driving a sports sedan is supposed to feel like! Here's a link: For RWD: https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 For XDRIVE: https://www.kiesmotorsports.com/prod...8;_ss=r?aff=22 |
SomethingBlue10.00 alohasurftoad3078.00 |
02-03-2021, 01:47 AM | #22 | |
Rep 1,369
Your post seems to indicate you changed only the thrust arm to VAC leaving the lower control arm OE (i.e. BMW). Is this the case? Having gone through three previous BMWs (two 3’s and one 2) I find it is the thrust bushing on the body side that gets the crap kicked out of it. It’s not that the hub side of the arm never dies but it seems to lot more mileage to kill it despite its smaller size. Even on the single wishbone E46, it was the front, not rear bushing that would leak first, then the hub side. I never had a rear side die. On F30 #1 it was the body side thrust arm bushing that started dying before any other bushing. Conveniently, it was one side but both sides would get swapped. I wonder if out of 4 bushings, over two arms, those two, large bushings aren’t the odd man out and just swapping them would relieve most of the grief noted by enthusiasts over BMW’s non-M front suspension. I want to make it clear that I’m not saying that swapping out the lower control arm has no advantage. While often not the prime reason for swapping out control arms (who complains "This ride is fine, but the projected longevity of the control arm bushing is sh*t. I can put up with driving around on a pillow but can't stand the thought of replacing parts at some point in the future. I got to do it now!"), VAC mono balls have also been praised for longevity. A blown bushing a few days before a track day is a pain in a$$. Because you have no time, being forced to replace it with an identical OE part is galling. On the other hand, a vast majority of parts in the car are fine. I'd like to keep the car as OE as possible. Too many stories of "I chattered my teeth to dust and now have to buy dentures or implants and put back the OE parts. Oh f*ck it, I'll drive around with just gums. Gums the Boy Racer with a car so slammed it would give a street cleaner a run for the money" I do find it stupid BMW will sell you an M Performance steering wheel for your XDrive but not M Sport control arms. Come on BMW, it’s just the bushing plus a couple of spacers. How hard can that be? Harder than a steering wheel swap? |
