02-23-2021, 01:31 PM | #1 |
Rep 2
430i GC Spring Dilemma
So I seemed to have found a gap in product availability designed for my 2018 430i GC, RWD. After speaking to a rep with Eibach and a couple hours researching the web, I have no clear path for purchase.
I would like to lower my ride height but keep my EDC in tact. I know H&R has an offering but based on other members experiences, I’d like another option. Can anyone speak on a solution for my setup? Someone with Eibach mentioned using a spring designed for the F30/32 chassis. Thanks for the help! |
02-23-2021, 01:43 PM | #2 | |
Rep 126
The other approach is to measure loaded and unloaded (out of car) spring height and have someone make you a custom set. This would probably be more expensive, but not by much. Also, FaRKle! created a suspension frequency calculator that might help you to fine-tune/match the desired spring rates. https://f30.bimmerpost.com/forums/sh....php?t=1721678 Good luck |
02-23-2021, 02:15 PM | #3 | |
Rep 2
I’ll have a look, thanks for the guidance. 🙏🏽 |
