07-31-2018, 06:47 PM | #23 | ||
Rep 5,776
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
07-31-2018, 07:05 PM | #24 | |
Rep 832
Drives: 2019 G01 X3
FYI, BM3 also has the speed limiter delete. |
07-31-2018, 07:53 PM | #25 |
Rep 1,105
The only real thing that BM3 has over MHD is the ability to resell the license if you sell your car but other than that they are very similar otherwise!
07-31-2018, 08:38 PM | #26 |
Rep 1,288
Gonna go BM3... Just to clarify... when I get in the car I still need a wifi connection for my computer correct...
07-31-2018, 10:14 PM | #27 | |
Rep 2,657
Flashed Stage 1 93 but I have AA FMIC, VRSF CP and MPPK upgraded intake. Didn't go stage 2 because no DP yet and as per BM customer service don't try it unless you want to destroy your CAT. Initial impressions? HOLY FUCKBALLS. I mean this shit just literally transformed my car. It feels like a rocket. SO MUCH POWER down low it's crazy. Car pulls like a motherfucker. Not sure about burbles though. I see the options to change it to OEM, OTS, OFF and Custom. When I choose the option that I want, do I have to flash again? Not sure how that works. Buy this shit NOW! That is all.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Sutphin Custom Tune - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI - Dinan Midpipe
FastF30521.00 |
08-01-2018, 01:32 AM | #28 |
Rep 1,392
BM3 or MHD
Thanks for all the inputs guys. I have never flash tune my car before. Is it easy to do?
Have 2014 f32 n55.m with Wagner FMIC, Fabspeed catted DP, vrsf charge pipe, PPK, and mpe. Should I go for stage 2? Type of output I can expect? Thanks all
2014 435i M Sport //AW, CR//premium, tech, lightening pkgs//20% tint//full clear bra//ppk//blk grills//20" Vertini wheels//digital gauge//Apple Carplay//MPE with catted DP//VSRF charge pipe//Wagner FMIC//
08-01-2018, 07:59 AM | #29 | |
Rep 2,657
Stage 2 with your mods.
reddemon73103.00 |
08-01-2018, 08:17 AM | #30 |
Rep 1,392
Do you guys have a recommendation for a good battery charger?
08-01-2018, 08:20 AM | #31 | |
Rep 1,499
Yes you have to re-flash anytime you make changes to the settings. The good thing is now that your DME is unlocked your future flashes will take about a minute.
Back on topic, one other advantage to bm3 is the flash times. I believe MHD takes about 15 mins to unlock and subsequent flashes are in the 5min range. bm3 takes about 5 mins to unlock with subsequent flashes being about 1min. Not a huge deal unless you like to switch maps frequently. Quote:
08-01-2018, 08:58 AM | #32 | |
Rep 2,657
STANLEY BC25BS 25 Amp Bench Battery Charger with 75 Amp Engine Start and Alternator Check https://www.amazon.com/dp/B01BYFSUJW..._JXByBbCCD8184
reddemon73103.00 |
08-01-2018, 10:42 AM | #33 |
Rep 1,392
I have a few more questions guys.
-I lived in the Seattle area and the most common octane around here is 92. Should I get the stage 2 91 or stage 2 93 flash? -I have PPK and MPE. I do get pretty good sound from my exhaust (burble and turbo spooling sound). The good thing is I can turn off the "loud" exhaust by switching to econ drive mode. This help from waking up the neighbors at 6am every morning. So, when I flash stage 2, there should be more "burble" sound, correct? Can I turn off the "burble" sound in econ mode? -From my research, my PPK tune will be saved in the stock setting and I will not loose this, correct? When I take the car to the dealership, I can re-flash to stock. Will the dealership be able to pick up on the bootmod3 flash? Thank you.
08-01-2018, 11:42 AM | #34 | |
Rep 1,499
1. Use 91 octane tune, stage 1 with stock cat and fmic.
2. Before you flash go into the configurator and make sure you've selected the exhaust flap to OEM. The reason the ECO mode is quiet is because it keeps the exhaust flap closed. 3. Correct. MPPK will be saved as your stock map. Flash back to stock and lock. There will be no tamper codes but if the dealer wants to dig a bit they will find things like torque values that are over stock values which points to a tune. It shouldn't be a problem unless you are trying to get a drivetrain component replaced under warranty. I would recommend finding a mod friendly service rep and be honest about your car being tuned. I did this in LA and now here in Raleigh and haven't had any issues for regular maintenance and getting OFH gasket and oil pan gasket replaced under warranty. One thing of note, when you flash back to stock you will get a CEL if you have catless DP. Quote:
08-01-2018, 12:42 PM | #35 | |
Rep 1,392
I am looking at stage 2 since I have Wagner intercooler, charge pipe, fabspeed catted DP, ppk, and mpe. Is that correct? Thank you.
08-01-2018, 01:46 PM | #36 | ||
Rep 549
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
08-01-2018, 01:59 PM | #37 |
Rep 1,499
No problem. I can't comment on the active sound. I have a 2014 F30 335i which didn't come with AS. Yes run stage 2.
08-01-2018, 02:39 PM | #38 |
Rep 2,657
I picked up a Raspberry Pi and case so I can get rid of the laptop when I need to flash, should be cool. I like that PTF allows you to do that, good stuff.
08-01-2018, 09:40 PM | #39 | ||
Rep 803
jgoens3787.50 |
08-01-2018, 09:41 PM | #40 |
Rep 5,776
I was just about to ask the same thing,
08-01-2018, 09:46 PM | #41 | |||
Rep 2,657
08-01-2018, 09:57 PM | #42 | ||||
Rep 803
08-01-2018, 10:03 PM | #43 | |||||
Rep 2,657
