07-03-2020, 09:10 PM | #177 | |
Rep 4,169
Have you considered measuring again with the Dinan? I’d recommend an air straightener (like a grill) for the intake to help stabilize the air reading. From your last logs, the Dinan was worth about 10whp than the current setup |
sspade2467.00 |
07-03-2020, 10:45 PM | #178 | ||
F36 GC
143
Rep 259
07-04-2020, 10:36 AM | #179 | |
Rep 4,169
But yes, I’m urging you to reconsider by using a MAF air straightener. - I’m trying to build a more efficient intake, so I’m going to try one myself. No reason to leave potential power (especially at top end) because of a small screen. |
07-04-2020, 11:48 AM | #180 | |
Rep 7,620
And yes, the hinge is not there on the real mppk box since it already comes with 2 openings. Its only there on the normal one incase snow blocks the normal intake behind the grills. |
07-04-2020, 11:51 AM | #181 | |
Rep 7,620
07-06-2020, 01:49 PM | #182 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Amazing and truly apprecaite you guys going above and beyond to test each (almost) turbo inlet. When I read this thread start to end, I thought Pure's inlet would be best but thejeremyman9 and ozymandias435 test seem to say otherwise.
With that being said, I currently have a N55 with PWG, do I get the stock MST setup or Hybrid? Seems like all response in this thread has been for EWG. |
ozymandias435142.50 |
07-06-2020, 01:58 PM | #183 | |
Rep 7,620
I did not see different MST inlet options for EWG vs PWG, and i am pretty sure the turbo housings on the inlet side are the same on EWG and PWG? Perhaps someone can confirm? You can also call Kies or XPH to confirm that question (although they will probably tell you to get the v1/stock turbo option, i would still get v2, you just need to confirm they fit in the PWG turbo). We both got the hybrid turbo option for MST, running on stock EWG turbo. The only difference between the stock turbo option ("v1") and the hybrid turbo option ("v2") is the metal piece that goes into the turbo. The stock turbo one is just thicker and therefore smaller ID (same OD based on sliding into the turbo)... so there is no reason really to get the smaller stock turbo one as it just restricts the airflow more further upstream. I'm sure the pure inlet works fine, and is definitely still an improvement over stock, but if you havent purchased one yet, i would go MST for all the reasons stated in previous posts. |
07-18-2020, 03:28 PM | #184 |
Rep 643
there's alot of attention on the turbo inlet pipe ID, however, has anyone assessed the inner diameter of all the other hoses/pipes in the intake tract from the air filter to the throttle body? for example, i notice the vrsf chargepipe decreases in diameter at the silicone coupler.
M235i rwd 6mt
07-19-2020, 08:44 PM | #185 | |
Rep 7,620
07-28-2020, 01:36 AM | #186 | |
Rep 62
KWV1’s, Remus sport exhaust, VSRF hi-flow cat, TIC & Charge pipes, 5” stepped intercooler; turbosmart BOV,MST V2 inlet, MHD Stage 2, oem m437 wheels, m performance alcantara steering wheel.
07-28-2020, 11:24 AM | #187 | |
Rep 7,620
I need a take a closer look at the Dinan intake because Ozy actually shipped me his so that i can experiment with it on my car, but there are two issues - one is that the MAF is in a circular area so does not contact the same fraction of the flow as stock, and it does not have the same intake mouth and draws air in from all directions. I do plan to do some future testing on it, on my car, but just got my car running 100% again after BMW created some boost leaks so it might not be for a little while. |
09-10-2020, 10:49 AM | #189 |
Rep 928
anyone cut the factory inlet and fit the vader piece in? that's what i'm gonna so in a week. it's only 60 bucks? it does look short, but they told me it will work with factory inlet pipe.
09-10-2020, 01:43 PM | #190 |
Rep 7,620
I know ozy and a few other people ran the VRSF which is basically the same thing. However i dont think the performance benefit compares to the MST v2. I would just do it once and do it right and get the MST v2, especially because of how annoying it is to remove and install the inlet. You will probably end up breaking one of both of the mounting tabs on the stock inlet during removal or reinstall. You should also probably replace the CCV hose as preventative maintenance while you are doing it; it can also be cracked during removal and reinstall.
09-10-2020, 01:55 PM | #191 | |
Rep 928
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
09-10-2020, 02:11 PM | #192 | |
Rep 7,620
https://www.fcpeuro.com/products/bmw...se-11127599753 |
1bad14-F3030.50 |
09-10-2020, 02:14 PM | #193 | ||
Rep 928
09-10-2020, 02:31 PM | #194 |
Rep 1,148
Anyone running the cts turbo intake with the upgraded inlet? Curious to see if it's more stable than the Dinan and closer to the stock air box since it has its own maf housing
09-10-2020, 02:57 PM | #195 | |
Rep 7,620
Inlet to valve cover. You can see it as soon as you remove the engine cover. Its a 4-pronged clip on the VC side.
The CTS should read more 'properly' based on the MAF housing design, but i would also like to see logs with CTS intake vs stock with any inlet. |
kitchener2.00 |
09-10-2020, 03:05 PM | #196 |
Rep 1,148
Awesome I saw people with erratic readings with the Dinan intake and someone reported sluggish feeling with it on, so I was just curious how the cts looked on paper it anyone has ran it with the inlet or anything
If no one has I'll report back when I do it |
kitchener2.00 |
09-10-2020, 09:53 PM | #197 |
Rep 1,288
The flow straightener looks more like restricting the inlet causing higher velocity on the speed sensor... basically putting your thumb on the end of a water hose... Just my opinion...
Best thing probably to do is attach streamers to the opening and just add fins until they flutter smooth... Just my opinion.. Last edited by FastF30; 09-10-2020 at 09:59 PM.. |
10-25-2020, 12:15 PM | #198 |
Moto Lover
187
Rep 591
For those that bought the MST turbo I let, did you guys get the stock or hybrid adapter? I have an F30 N55 wit PWG, stock turbo.
Honestly, what is the difference? Ones for stock and one is for aftermarket turbos? |
