BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Code for fan to remain off at start?
      09-19-2022, 12:20 AM   #1
maximus81
Drives: 2014 BMW 320D M-Sport (F30)
Currently, when I start the F30, the fan comes on automatically. Is there any code where I can change something so that the fan doesn't turn on when I turn the ignition on? I got both carly and bimmercode.
      09-21-2022, 10:27 AM   #2
armenio1986
Bmw driver
Drives: 2016 320i F30 Sport GP
Fan refers to the air conditioning?
      09-21-2022, 04:48 PM   #3
maximus81
Yes aircon fan but the aircon part is off. It's only the fan that comes on during ignition.
      09-22-2022, 04:36 PM   #4
armenio1986
Bmw driver
Coding solves this for you.
you can do it with e-sys (requires advanced knowledge in coding) or you do it with the BimmerCode App (which has an intuitive interface)
      09-23-2022, 05:04 AM   #5
maximus81
Yes I know and the first post is to ask for which values I need to change in bimmercode.
      09-23-2022, 06:24 AM   #6
cjn
Drives: 2021 F40 M135iX
Why not just look at what BC is offering under Air Conditioning? There are at least 3 options that should apply to your car. Just pick one or more and see what happens. You won't break anything!
      09-23-2022, 06:55 AM   #7
maximus81
I tried but the option only affects the aircon but not the fan itself. I am sure there will be something in expert mode but i just dont know which option is it.
      09-23-2022, 08:11 AM   #8
cjn
For a 2014 F30, BC gives the options:
Air circulation setting memory
Enable/disable storing of the air circulation setting. If this function is active, the last used air circulation setting will be restored during the next start of the car.
Values:
Active
Not active
Requirements:
“Air Conditioning” IHKA_VA01 or “Air Conditioning” IHKA_VA02 control unit
Air conditioning on in AUTO mode
Enable/disable the automatic activation of the air conditioning when the AUTO mode is turned on.
Values:
Active
Not active
Requirements:
Air conditioning setting memory
Enable/disable storing of the air conditioning setting. If this function is active, the last used air conditioning setting will be restored during the next start of the car.
Values:
Active
Not active
Requirements:
Automatic Air Recirculation
Enable/disable the Automatic Air Recirculation function.
Values:
Active
Not active
Requirements:
Are you certain that none of these solves your problem? If that is the case I think you are out of luck. Why are you so sure that expert mode is the answer?
      10-02-2022, 06:00 AM   #9
maximus81
Values:
Active
Not active
Requirements:
Values:
Active
Not active
Requirements:
Values:
Active
Not active
Requirements:
Values:
Active
Not active
Requirements:
Unfortunately none of these options solves the issue. Expert mode generally has more settings that are not available in normal mode.
