BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Oil Filter Housing Gasket Leak Repair costs???
      05-21-2018, 11:27 AM   #1
yoon_209
Masterchief
yoon_209's Avatar
Drives: 20' BMW M340i
Anyone have any rough estimates as to how much this should cost at an indy shop??
Im being quoted $750+ which i believe is pretty steep for this type of service which shouldnt take 4 hours max.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT
      05-21-2018, 11:36 AM   #2
enjoythemusic
enjoythemusic's Avatar
364
Drives: 2014 BMW 435i Dinan Stage 4
There's a recall on N20, so should be free.
http://www.bimmerfest.com/forums/sho...d.php?t=951692
Enjoy the Drive,
Steven
2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S.
      05-21-2018, 11:45 AM   #3
yoon_209
Masterchief
yoon_209's Avatar
I have a n55
      05-21-2018, 11:47 AM   #4
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Thanks for the heads up, Ill stash that for later in case I have any issues...
      05-21-2018, 12:20 PM   #5
enjoythemusic
364
Originally Posted by yoon_209 View Post
I have a n55
Oh man... bummer.
Enjoy the Drive,
Steven
      05-22-2018, 11:12 AM   #6
Orion4
Anyone have any rough estimates as to how much this should cost at an Indy shop??
Im being quoted $750+ which i believe is pretty steep for this type of service which shouldn't take 4 hours max.
Is this for both gaskets? FCP has the kit for both and associated parts for less than $80. I changed my front gasket in about 30 min. the Rear takes more time and disassembly. So I would liberally estimate 60 min. Therefore, less than 2 hrs. No way it is a 4 hr job. I did an oil and filter change at same time. Any decent Indy shop should only charge about 2hrs of labor and less than $90 for parts. Don't know what your Indy labor rates are in CA.
      05-22-2018, 11:21 AM   #7
yoon_209
Masterchief
yoon_209's Avatar
called about 5 different shops (not dealerships) and they all quoted me 5.5 hours at 100-130/hr.
tools and parts only cost me 250
      05-22-2018, 11:24 AM   #8
yoon_209
Masterchief
yoon_209's Avatar
im guessing im gonna need to replace all my belts as well since its been leaking for a while now and im just getting to it.
besides the serpentine, AC and alternator belts, are there any other belts im missing?
      05-22-2018, 11:53 AM   #9
enjoythemusic
364
Maybe the shops think it is the N20 which is said to take ~4 hours versus a N55 which is less?????
Enjoy the Drive,
Steven
      05-22-2018, 12:01 PM   #10
yoon_209
Masterchief
yoon_209's Avatar
i specificaly stated n55 335i unless the techs are dumb as fuck.
aps335.50
      05-22-2018, 01:18 PM   #11
enjoythemusic
364
Well, hmmmm... have no idea how long the N55 takes, yet have heard the N20 takes about 3 to 4 hours. We just discovered the wife's 2013 X1 has this problem during oil change at dealership last week. BMW of Sarasota is fixing her N20 for free under recall
Enjoy the Drive,
Steven
      06-04-2018, 10:45 AM   #12
yoon_209
Masterchief
yoon_209's Avatar
I did this in my garage yesterday. Took my 3.5 hours from start to finish.
Costs me 150 for impact wrench, torx socket kit and gaskets...
Still can't believe a shop quoted me 6 hours of labor.
Big shout out to Youtube DIY videos and f30post.
      06-06-2018, 12:10 PM   #13
_bdiddyb_
Drives: 2013 335i
yoon_209 , now comes the cleaning right? I had oil all over the front of the engine and underneath. Another 2 hours of meticulously cleaning everything.
      06-06-2018, 12:12 PM   #14
yoon_209
Masterchief
yoon_209's Avatar
Ya i did as much as i can to clean up the surrounding area. It wasnt as bad as i thought however i do need to remove the belly pan thing cause im sure there is oil that has accumulated.
      06-07-2018, 09:20 AM   #15
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
dealer only charged me $300 including parts
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      06-07-2018, 10:14 AM   #16
yoon_209
Masterchief
yoon_209's Avatar
what dealer? cause im tryna get a price match for that next time
      06-07-2018, 10:19 AM   #17
sspade
sspade's Avatar
Drives: F30
Towne BMW, I presume.
That is a nice number. Pretty surprised.
Edit: I was thinking Buffalo area for some reason...
      06-13-2018, 03:47 PM   #18
IraHayes
Drives: 328i
It you have an all aluminum housing you’re OK. Early on, Bmw used a plastic filter housing on the N20/26. The plastic units are the ones that are prone to fail. The recall replaces these with the aluminum unit.
      02-14-2019, 11:50 AM   #19
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
What video did you follow on YouTube?
      02-14-2019, 11:52 AM   #20
yoon_209
Masterchief
yoon_209's Avatar
there are various videos. i dont remember off the bat.
jus search bmw n55 ofhg change. theres tons of diys on youtube
      02-14-2019, 11:57 AM   #21
sspade
sspade's Avatar
Drives: F30
I have an OEM set (brand new, in the wrapper) of OFHG if anyone is interested.
PayPal or Zelle accepted.
PN's
11428637820
11428637821
      02-14-2019, 12:00 PM   #22
Logicoeur
Logicoeur's Avatar
991
I figured, Thanks. I've watched a couple of them. Still can't decide if I want to fork over the $860 with belts swapped, or do it all myself. Don't have a garage and it's pretty cold up in the NE right now for the foreseeable future.
