BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > HU ENTRYNAV to NBT Evo ID6 retrofit issue
      08-08-2020, 06:00 AM   #1
greig330
Drives: E85 3.0i, E91 330D, F31 330D
Hi all.. I have a 2014 F31 with ENTRYNAV which I am attempting to retrofit a NBT EVO HU into..
The new HU has a GPS input (as my car has no ATM) and was coded for my car with new 2020 maps installed,and wide-screen Apple carplay unlocked.
After install, everything worked fine until I turned the ignition off and locked the car.. apple carplay was running at the time.. the screen flickered back to the BMW menu screen before turning off.. I mention this as it didn't look quite right..
The next time I started the car, apple carplay was not available (it told me so!) and now BMW Navigation will not even start - the menu box just says "Loading.."
Can any expert help with what has gone wrong here?
Best regards,
Greig
      08-11-2020, 09:06 AM   #2
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Best regards,
Greig
Was the headunit coded to your VIN number, you need to check if the FSC codes have been rejected - use esys for this.
