05-24-2016, 12:42 PM | #45 | |
Rep 49
RPM and MPH
06-23-2016, 12:45 PM | #46 |
Rep 40
Drives: 2022 BMW 230i M Sport
So I got the wife's 340i xDrive on the Rhino Ramps last night and crawled under the car for the first time, in anticipation of doing the first oil change this weekend. I was surprised by a couple of things.
First, the 340i does not have a drop-down door for the oil pan compartment. It's just an opening (no door or hatch). The same is true for what appears to be the front differential drain plug (at least I think it's the front diff drain plug). I know what you're thinking -- the dealership took them off for some reason or they were inadvertently missed on the line. However, we bought the car new (six miles) and there appear to be no hinges or anything else that would suggest that engineers wanted a door/hatch covering the drain plugs. Second, there is no front/center jack point nipple as there are on other models. Where that jack point protrusion is/was on other models is now a flat surface that is consistent with the surface of the surrounding area in front of the oil pan. I was hoping to use front/back center jack points with the floor jack so that I could use jack stands on the four jack points along the side frame (behind front wheels and in front of back wheels). The ramps simply do not provide enough lift to work comfortably under the car. Any thoughts or insight on these observations would be greatly appreciated. |
10-09-2016, 11:10 AM | #47 |
Rep 150
I'm curious... is the oil filter housing on the B58 plastic or aluminum? I remember there being a recall for the N20s to replace the plastic oil filter housing with an aluminum one...
10-10-2016, 11:09 AM | #49 |
Rep 210
4K imo is a bit excessive and a waste if you are using synthetic. but thats just me, prob no real benefits but to each his own
Car List: 2000 328i E46 Steel Gray Metallic 5SPD MT- Sold 2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current |
m3roman2.00 |
10-10-2016, 02:49 PM | #50 |
Rep 703
Some do an initial oil change around 2-4K mi after break in but other than that it's a waste to do oil changes earlier than every 7.5K mi. with full synthetic oil.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
F30MGM196.00 |
01-19-2017, 03:17 PM | #51 |
Rep 140
Anyone in NY willing to help me with my oil change?
Thanks!
2016 340ix M Sport /// Mineral Grey Metallic /// AWE Exhaust & Midpipe /// BMS Intake & OCC /// JB4
01-23-2017, 04:09 PM | #52 |
Rep 140
Can someone confirm, is the B58 oil pan aluminum or metal?
Same for the oil pan plug, is it aluminum or metal? Thanks, Mike
02-02-2017, 10:02 AM | #53 |
Rep 210
It's easy. Process is almost same as any car except for oil change. Try doing it yourself. It's much more rewarding
mikeleeyh40.00 |
02-02-2017, 02:27 PM | #54 | |
Rep 10,185
B58 oil pan is listed as being die-cast Aluminium Plug should be steel
BMW if you are reading, I need a job, Please. |
mikeleeyh40.00 |
02-02-2017, 02:52 PM | #55 |
Rep 140
Did my oil change last night after work. Definitely not hard at all. I always did oil changes in the past with my previous cars but for some reason, working on BMWs is nerve-racking. Guess I want everything to be perfect.
02-02-2017, 02:53 PM | #56 | |
Rep 140
Awesome, thanks for the confirmation, just wanted to be sure. So when I put the oil drain plug back on, I didn’t torque it. Just put new crush washer and tightened until it was snug. Then gave it a little more to be secure.
02-06-2017, 03:58 PM | #57 |
Rep 303
What are the correct torques for the oil drain plug and oil filter cover ???
I've been reading the B58 technical training manual and i couldn't find those numbers... Thanks. |
02-07-2017, 10:43 PM | #60 | |
Rep 331
Drives: M140i F20 LCI-2
02-11-2017, 11:10 AM | #62 |
Rep 210
I used it for one oil change no issues. ll-01 I think can still be used for ll-14
02-11-2017, 06:49 PM | #63 | |
Rep 331
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016. Sold: Alpine White 123d e82, 2010, 150kW/204hp. |
03-18-2017, 10:21 AM | #64 |
Rep 5
Oil is Cheap
I just took delivery of a new 440i (MPSK, Track Handling pkg, 6 sp - very fun car). I am old school, especially with turbos. If you don't mind replacing a very expensive, very hot, very fast spinning part in a few years, please follow BMW's wonderful recommendations. And, BTW, the fast spinning thing is now integral with the exhaust manifold....that should make it cheaper to replace . Otherwise, like my friend says, even oil made by the hand of god should be replaced every 5k or sooner (sooner). I'm sure that many owners plan to return the car in 2-3 years. I am not that owner. Oil is cheap.
04-12-2017, 01:17 PM | #65 |
Rep 548
Drives: 2011 E90 M3 ZCP
Just wanted to update this, as I finally had my 1st oil change service performed. They did in fact, use BMW TwinPower Turbo Oil (83-21-2-365-954) 0W-20 LL14 with an OEM filter (11-42-8-583-898). The service interval is now 8000 miles (as per iDrive).
Was a pretty painless procedure (It was nail-biting the whole time, as I hate taking my car in for service). They had me in and out pretty quickly and respected my car the whole time (was creepily watching from a far). They also didn't mind my mods either. |
04-19-2017, 02:27 PM | #66 |
Rep 48
This looks like a fairly simple oil change. What about the the on board computer? Any special procedures for this? I owuld prefer this oil change I perform not effect the existing counter.
