11-12-2019, 11:18 PM | #1 |
Rep 179
Setting up new TPMS
I have a 2014 428i xdrive, I just got 4 new ones, do I just need to reset the option on the settings, drive a bit and voila?
11-13-2019, 12:06 AM | #2 |
Rep 941
When I put new wheels on my 2015 model, the TPMS sensors connected with the car seamlessly. Same as you propose, I reset in the car to ‘store’ the current pressures as those for the system to watch for.
11-13-2019, 03:31 AM | #3 |
No 55mph
1616
Rep 8,474
Yes
11-13-2019, 09:33 AM | #4 |
Rep 849
Drives: BMW 435i
On my version of iDrive, it automatically opened the screen asking whether I wanted to reset the TPMS as soon as I started driving on my winter wheels.
One thing I noticed is the reset will work much quicker if you are driving somewhere without stopping. My route at the time had several stop signs and red lights, so the re-set process kept pausing every time I dropped below a certain speed. Took almost 15 minutes to complete the process. |
11-14-2019, 12:10 PM | #7 |
Rep 2,799
Drives: F33 430 and F39 M35i
I usually just hop on the interstate after doing my winter/summer swap and it resets quickly enough. No city driving with too much stop and go.
I switched my exwife’s wheels over and her setup has a handheld transmitter that you walk up to each wheel in sequence and it resets it that way. 2015 Camaro My daughter’s car i have to add or drop a few psi in each tire in a sequence for it to reset. 2008 buick The transmitter is the easiest/fastest. |
11-14-2019, 01:59 PM | #8 |
A family of bimmers
2744
Rep 7,741
Once I've topped off the tire pressure with a digital gauge as well i just hit reset once ive backed away down my driveway far enough from the other sensors and do a loop around the neighborhood and it resets probably in a 1/4 mile. cant see it being harder than that. It also allows me to verify that i dont hear or feel any driving issues
11-14-2019, 09:38 PM | #9 | |
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
