01-14-2022, 12:37 PM | #1 |
Rep 4
Cannot code SAT on F30
Hello new here,
I have 2013 F30 3.16i which is equipped with N13 and ZF8HP45. I tried to code SAT on the BimmerCode and it didn't do anything as I still had the DS instead of S1-S2... and the shifting was still the same. I have 205 instead of 2TB. Is there any way I can code SAT? |
01-15-2022, 03:20 AM | #2 |
New BMW owner
139
Rep 621
You should use ESYS instead of Bimmercode.
01-15-2022, 03:56 AM | #3 |
Rep 5,457
It works, done it personally on two F30 with BimmerCode.
Dont forget, there are four changes you need to make (within different modules) before 2TB will be active. |
01-18-2022, 09:32 AM | #4 |
Rep 4
01-18-2022, 10:35 AM | #5 |
Rep 5,457
Electronic Transmission Control
1. Sport Automatic Transmission > set to Active Headunit 2. SPORT driving mode configurable > set to Active Instrument Cluster 3. SPORT+ driving mode > set to Active Integrated Chassis Management 4. SPORT+ driving mode > set to Active |
xeryla0.00 |
