04-15-2019, 06:36 PM | #1 |
Rep 42
bmw F30 335i Xdrive
Hi everybody,
I’m new to the forum and to BMW and have a question to ask you! I just purchased my 2013 335i Xdrive M pack and needed to buy summer tires. I realized the stock tire requirements is 225/40/19 for the front and 255/35/19 for the rear AFTER I purchased some tires! The front tires I bought are Michelin Pilot SuperSports size 235/35/19 Whereas my rear are 255/35/19 I’d like to know if it’s safe for my xDrive system to run with those front tires. Would anybody be kind enough to help out? The mags i have are 269 M performance mags, front: 8J x 19; rear 9J x 19 Also, my car is dropped by an inch on H&R springs!!! I’d really appreciate if someone could help!!! |
04-15-2019, 07:22 PM | #2 | |
Rep 1,986
Drives: 2014 335i xdrive, 2014 X5 3.5d
04-15-2019, 07:34 PM | #4 |
Rep 259
See below, I believe for x drives the rolling diameter shouldn't be greater than 1%
I haven't had to replace my tires yet as I just bought my 435 xdrive not long ago and I'm still tryin to figure this issue myself as rims and offsets and so forth matter in this measurement as well. Use www.willtheyfit.com to check the specs of ur setup and post the data when you can |
04-15-2019, 08:28 PM | #5 |
Rep 42
Alright! Thanks guys, I have a feeling it’s not going to be healthy for the Xdrive... I’m probably going to end up selling them locally and get myself the exact recommended tire dimensions to remain on the safe side.
Thanks! |
04-15-2019, 08:50 PM | #6 | |
Rep 5,399
I just got Michelin Pilot Sport 4S summer tires. Just amazing! Have fun! |
alohasurftoad3124.00 |
04-16-2019, 11:03 AM | #7 | |
Rep 97
04-16-2019, 09:05 PM | #8 |
Rep 4,371
oem staggered 225/40/19, 255/35/19 fits perfectly on 8" and 9" and their 0.4% diameter difference will cause no issues for the x-drive transfer case.
in descending order from the best...michelin pilot sport 4s > continental extremecontact sport > general gmax rs, falken azenis fk510, firestone firehawk indy 500. the last three UHPS are kind of all equal. gmax rated highest per test, firestone rated highest by customers. you may also go a tick up in size 235/40/19, 265/35/19, however your tire choices are kinda limited to the MPS4S and Contininteal ExtremeContact Sport and both are much more expensive at this size. Last edited by alohasurftoad; 04-16-2019 at 09:15 PM.. |
