Login
02-08-2021, 11:55 AM | #67 |
![]() 3
Rep 53
Update..
As i mentioned i had few misfires in all cylinders with no pattern. I've decided to try 98 octane in my last stop at the gas station (different one from where i usually go). Guess what, ZERO misfires ! (I'm using torque app in every drive to monitor misfires). What a joy 😜. Next step, logging some pulls and eventually going back to stage 1 (it's so slow right now, it's embarrassing) |
02-08-2021, 11:17 PM | #68 | |
![]() 12
Rep 68
02-09-2021, 09:58 PM | #69 | |
![]() ![]() ![]() 158
Rep 311
i've been running stage 2 BM3 91oct for 8k miles, drives hard, no problem so far on my B48 engine
Instagram: nightfall.f30
02-13-2021, 01:16 PM | #70 |
![]() 3
Rep 53
Hi, will appreciate your thoughts on those logs.
1. https://www.bootmod3.net/log?id=6028...0b4346b9c7c33a 2. https://www.bootmod3.net/log?id=6028...729b454c0c5f55 3. https://www.bootmod3.net/log?id=6028...0b43474d7f52d5 |
02-13-2021, 11:54 PM | #71 | |
![]() 12
Rep 68
02-14-2021, 04:36 AM | #72 |
![]() 3
Rep 53
02-14-2021, 06:21 AM | #73 |
![]() 12
Rep 68
02-15-2021, 12:13 PM | #74 |
![]() 3
Rep 53
Ok, so I've tuned it to 91acn and did some logs.
1. https://www.bootmod3.net/log?id=602a...729b45d64d076d 2. https://www.bootmod3.net/log?id=602a...90c61a188c24e8 3. https://www.bootmod3.net/log?id=602a...729b45d64d076e 4. https://www.bootmod3.net/log?id=602a...90c61aac721f85 5. https://www.bootmod3.net/log?id=602a...90c61a188c24e7 Your thoughts would be appreciated. On the first pull (the third link) i see a knock 😬 |
02-15-2021, 11:35 PM | #75 | |
![]() 12
Rep 68
02-16-2021, 08:03 PM | #76 | |
![]() 1768
Rep 3,401
Its not great to get knock at WOT but if your timing is otherwise clean with little to no corrections and your IATs are in check, its really no cause for big concern. If you were consistently getting knock in every pull, then yeah, you should investigate further, but if its rare, not a big deal. If you want to learn about how to interpret datalogs you can read my thread here: https://f30.bimmerpost.com/forums/sh....php?t=1732327 |
