Login
02-10-2021, 02:17 PM | #4467 | |
![]() 1768
Rep 3,401
https://f30.bimmerpost.com/forums/sh....php?t=1734786 Here's a thread on spool street that discusses the same [remove the spaces]: https://www. s p o o l s t r e e t . com/threads/secondary-o2-sensors-tuned-still-needed.4877/ Maybe your car is different... interested to see your fuel trims. |
Korvo342.50 |
02-12-2021, 01:17 AM | #4468 |
![]() ![]() ![]() ![]() 57
Rep 462
My pragmatic analysis continuation and end:
The first pre-catalyst probe is used to send a data signal to the DME for a calculation necessary for the settings The second post-catalyst probe is only used to read data from the first. BUT: the DME waits for 2 signals to make its calculation necessary for the vehicle settings. In this case, reprogramming allows: - Modification of the calculation by the DME by removing the wait for the secondary probe signal and by adjusting certain parameters (mapping option) - The modification of the 2 signals sent by deleting the reading of the post-catalyst probe, making it appear that it is still in place (monitoring option) My conclusion : This second post catalyst probe must be in place! I have this Wagner catalyst removed on Wednesday 02/17/2021 and I put everything back original **, thus removing the incomplete and noisy work for my vehicle from the chosen garage. End of Off topic and I would like to thank MHD here for its support and explanation, as well as BMW HORIZON France. ** I have worked hard to afford the car of my dreams and will take every precaution to keep it as long as possible. Last edited by F20_M135i; 02-13-2021 at 01:16 AM.. |
02-16-2021, 12:27 PM | #4469 | |
![]() 1768
Rep 3,401
F20_M135i56.50 |
02-17-2021, 01:46 AM | #4470 |
Rep 462
Hello friend, Yes I am waiting for a response from WAGNER for the reimbursement of this unsuitable Downpipe, I hope they will say yes.
For now I have made the decision not to ride any more, maybe I will do that later ![]() |
02-18-2021, 06:39 PM | #4471 | |
![]() 1768
Rep 3,401
https://f30.bimmerpost.com/forums/sh....php?t=1794476 https://f30.bimmerpost.com/forums/sh....php?t=1699972 |
F20_M135i56.50 |
02-19-2021, 12:19 AM | #4472 | |
Rep 462
![]() Quote:
I have chosen to return the part for refund. And for sharing and more precision, here is what results in forcing the installation of the post catalyst sensor on a DP WAGNER (vehicle F20 N55 PWG): ![]() ![]() ![]() ![]() The garage decided not to mount the post catalyst probe because this would have had the effect of breaking with the vibrations, we can also see that its installation pushes the heat protection plate! - END OF EXCLUSION - There was an update yesterday from MHD with changes but I believe what is missing ... I would like the possibility of "preparing your flash" and above all, of having "a history of the last" offline. Let me explain: When we discover the possibilities of this application, we test a lot of options, parameters and courses ... But in combination with another software (like Xhp Flashtool for example) we can quickly get lost in all these settings ... The MHD TUNING application should save the last STAGE flash with all its chosen parameters (fuel, gearbox mode, burble options ... etc) So that all this is available offline from the car and that we can consult it at any time What do you think ? ![]() |
02-19-2021, 01:12 AM | #4473 | |
![]() 1768
Rep 3,401
02-19-2021, 01:18 AM | #4474 |
Rep 462
Except that in the case of MHD you are required to take X2 screenshots for the options chosen, and X1 for the internship while for Xhp Flashtool you can prepare your options and your flash offline and offline from the car. think that wouldn't be a good bonus for MHD?
02-19-2021, 03:29 PM | #4475 |
![]() 6
Rep 40
Here is the situation. BMW is asking if they can reflash all the modules which they would need to do to retrofit a control module for the Auto/Manual HVAC (they are aware of all the mods and tune and have been awesome about it). I see on MHD site it say in bold red letters that cars with newer BMW software would need to be bench unlocked. Not sure what that means and am in danger of being in that category if I let them reflash the car with what I assume is newer software? How is that different from when MHD unlocks the DME the first time you flash? Thank you people for any thoughts.
02-19-2021, 06:30 PM | #4476 | |
![]() 1768
Rep 3,401
I had a software update done in late 2019. Not sure exactly what modules/software were updated, but it cleared all my setting/memory/etc in the car and i basically had to go through the idrive and redo everything. I was able to flash MHD no problem. I do recommend that you flash back to stock / uninstall MHD / relock the DME before doing any kind of software update, even if the dealer is fine with you being tuned. Its quite possible it will mess with the tune in some way, and its the safest in my opinion to go in with a untuned car, come out with a updated untuned car, then reflash MHD as a fresh install. This will also be sure that your newly updated software is saved as your stock file with MHD. I am pretty sure, but not certain, when they refer to the newest software they just mean the newest DMEs for new models, which always take some time to be cracked before they can be OBD flashed vs. bench flashed. |
chrisman2106.00 |
02-19-2021, 06:42 PM | #4477 | |
![]() 6
Rep 40
02-22-2021, 10:43 AM | #4478 | |
![]() 6
Rep 40
EDIT: MHD just reached out saying for N55 it should be good Last edited by chrisman210; 02-22-2021 at 02:11 PM.. |
02-24-2021, 03:10 PM | #4479 |
Rep 462
Small incident yesterday on the road = broken glass
![]() Exploded windshield and headlight optics (projection of pebbles at over 80km/h) Tomorrow, expertise of the insurance of my vehicle and therefore deposit at the original BMW garage. Goodbye MHD & Xhp, return to the origin for the gearbox and the engine in less than 10 minutes: too good ![]() |
02-25-2021, 09:50 AM | #4480 |
Respect My Authoritah
![]() 343
Rep 870
So has anyone used anti-lag? Could you share thoughts?
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
Tags |
flash, mhd, tune |
