BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > ZF-8 un-commanded downshift
      09-22-2021, 01:11 PM   #1
erickonphoenix
erickonphoenix's Avatar
Drives: Gray 328xi Touring
First time this has happened.
Car in Sport plus, ZF-8 in manual mode, entering a slow corner under braking I downshifted to M4, M3, M2 then accelerated out of the corner. Shifted to M3 then to M4 when suddenly the transmission kicked down to M3 un-commanded pegging the car to redline. I hit the upshift again and it bumped back to M4.
I'm new to the ZF-8, I know the trans will upshift even in manual mode but I've never heard of one downshifting under load.
Now, one of my buddies (not a BMW person) speculated maybe I could have knocked the shifter out of manual mode. I didn't think to check when it happed but driving back I noticed the ZF-8 was back in auto mode and I don't remember changing it.
      09-22-2021, 05:54 PM   #2
indyjoeshmo
Drives: F30 335i Sedan
Does the intervention of traction or stability control revert the transmission to auto mode? I have a manual, so I'm just throwing out ideas.
      09-23-2021, 11:04 AM   #3
FaRKle!
Drives: '17 328d Wagon, '21 M2 Comp
Is kickdown still active in the configuration you were using?
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      09-23-2021, 12:13 PM   #4
erickonphoenix
I had TC off so it's possible there some undetected slip and the ZF-8 reacted, but a downshift? Seems it would upshift or depending on the intelligence of the system reduce power to the rear wheels???
I really don't know. Kickdown usually happens when you go full throttle in too high a gear then the ZF-8 drops down to optimize the power band. The kickdown in this instance was abrupt and startling.
      09-26-2021, 12:28 PM   #5
JoHnMuir
Drives: BMW 340i
I believe in the 328s the transmission is programmed to always have this behavior regardless of mode. I remember reading this was changed with the LCI and my 340i certainly does not exhibit this behavior. In Sport+ and manual mode (with shifter in sport mode) I can hit the rev limiter and be in whatever gear I want and the car won't do anything about it. The only thing it still does it auto select 1st gear when at a stop.
      09-26-2021, 06:55 PM   #6
alexander7599
Alexander Hartunian
alexander7599's Avatar
Drives: 2018 BMW 440i
2018 BMW  [0.00]
My 440i only downshifts when I click the kickdown trigger in auto or S/A. But never in M/S
2018 F32 440i - Black Sapphire Metallic | Stock
