09-24-2021, 11:57 AM | #639 |
Rep 420
E25. Port of Methanol. Target 28psi.
M140IX. Turbo Pure 800 Cast.
Uni-Rapide71.00 Ictus54.00 |
10-06-2021, 06:31 PM | #640 |
Rep 99
I lost the runs when I switched phones recently, but I still had this 0-60 screen shot and my 3 best runs on the Stage 2+ E30 map with methanol. 2016 340i, Dorch St2, Bootmod3 Stage 2+ E30, Snow perf Meth, FBO, stock turbo. Pure 800 is a few days away now after an 8+ week wait |
10-11-2021, 11:04 PM | #642 | |
Rep 298
17 BMW 340iX / DAW UF/ DS2 HPFP
10-11-2021, 11:11 PM | #643 |
Rep 298
WOW!!! This is crazy impressive. Have you considered bumping the ethanol content to make more power (say full E85)? Or do you feel that the law of diminishing marginal returns applies, whereby the incremental power from going full E85 isn't worth the bump in power? I know running E85 is significantly more expensive outside of the USA (I'm in Canada and ethanol is crazy hard to find and very expensive) - was curious on your take....
Thx in advance and congrats on the setup!
10-12-2021, 03:31 AM | #644 | |
Rep 420
10-15-2021, 08:59 PM | #646 |
Rep 420
1. Drag Mod Xhp.
+ 15C outside temperature. Draghi does not show it correctly
Uni-Rapide71.00 |
10-16-2021, 08:04 AM | #647 | |
Rep 99
I was stoked for the new XHP drag mode, but as soon as it warned me there is 4x wear on the clutch packs and can lead to slipping, I noped outta there hella quick. |
10-16-2021, 08:17 AM | #648 |
DisplacementReplacement
394
Rep 1,092
Exactly my concern but it sounds great performance wise!!!
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
12-14-2021, 04:43 AM | #651 |
Rep 1,800
Quite happy with the progress of the wagon.
Pump and port meth, full weight (1800kg) and it moves.
Europe's fastest (stock block) F31 340i RWD | MPPSK | XHP 3 | Pure800 | Port Meth | Dorch 2 HPFP | MG Flasher
Uni-Rapide71.00 |
12-16-2021, 06:19 AM | #652 |
Rep 164
Quick question, what kind of whp is it needed to reach a 130mph trap speed in the 1/4 mile?
My car is a f22 and it weights about 3800-3850lbs with fuel and driver onboard. Thanks |
12-16-2021, 07:29 AM | #653 |
Rep 420
520-540WHP
12-16-2021, 07:54 AM | #654 |
Rep 164
Thank you, I’m currently tuning my Pure800/Ds2 e50 tune, and that’s why I ask.
Quick question, I’ve seen some your dragy pulls and you consistently get amazing 60” times. Are you launching in 1st or 2nd gear? If im not mistaken I have the torque scaling at 20% and generally speaking, 2nd gear tends to get me more consistent times when I launch at 3k, this usually yields an average of 1.72-1.75 60”s. However, is there anything else you recommend in order to hit the 1.6x range? |
12-16-2021, 08:36 AM | #655 | |
Rep 420
DSC Off 1gear - 2600 start 500+whp. 2gear- 2900 start 600+whp
340mang3.00 |
12-16-2021, 08:39 AM | #656 |
Rep 164
03-26-2022, 06:46 AM | #657 |
Rep 1,800
Well this has fallen by the way side for a while so I thought I'd give it a bump
04-11-2022, 11:03 AM | #658 |
Rep 1,010
Self made tune negative slope heavy head wind.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
Skyhigh1879.00 WrxToBeamerGuy492.00 |
04-17-2022, 04:25 PM | #659 |
Rep 3,860
Heavy config 440iX, Stage 2 RON102 + Akrapovic Catted DP + MPPSK + xHP Stage 3 (default LC settings) I am very determined to break the 4s. threshold
IMS-340C394.50 |
04-17-2022, 06:29 PM | #660 |
Rep 1,467
