11-08-2020, 02:54 PM | #23 | |
Rep 4,130
The ATM only cools a few degrees more than the Evo2. The Dinan is barely better than the Evo 2, and costs even more. Avoid. OP gave his review with logs and someone else with no experience, no logs and 5 year old information comes in and says otherwise. Who are you going to believe? Last edited by AmuroRay; 11-10-2020 at 05:06 PM.. Reason: Grammar |
Pussiwillow521.00 LYTSOUT188.50 |
11-10-2020, 01:58 AM | #24 |
Rep 26
OK, thanks for feedback, here is news from my part :-) The shop I am helping to mod the F30 335xi ordered the Wagner EVO3 and they will try to put it in.. I will tell you.
In worst case, this beast will end in my E92 335i :-D
E92 335i (N54, Hydra Performance HP650, Ohlins suspension, Autosolutions SS)
alohasurftoad3067.50 |
11-10-2020, 06:58 AM | #25 | |
Rep 4,130
I double checked and you and I have had this conversation more than once - my answers have not changed. Also 90% sure it will not fit a E series. Good luck. |
Pussiwillow521.00 |
11-10-2020, 11:41 AM | #26 |
Rep 4,130
Sorry to the OP - but I HATE, literally despise they type of misinformation going on here:
https://f30.bimmerpost.com/forums/sh....php?t=1518971 Evo 2 getting beat in every single performance metric by the ATM. Maximum delta in cooling about "7-11 degrees" per the tester. https://f87.bimmerpost.com/forums/sh...&postcount=310 Per VRSF's claims - the Competition 6.5 cools better than any other similar sized cooler, including ATM, and CSF (he names CFS in another post) Finally https://f87.bimmerpost.com/forums/sh...&postcount=473 VRSF race log - complete with a comparison vs the Evo2. (spoilers - the EVO2 isn't that good) https://f87.bimmerpost.com/forums/sh...&postcount=589 dinan vs Evo 2 (spoilers - neither is that great)
Mods: Yes.
Pussiwillow521.00 sfelym9.00 |
11-10-2020, 11:50 AM | #27 | |
Rep 1,148
Logicoeur989.50 |
11-10-2020, 11:20 PM | #28 |
Rep 5,364
VRSF is well known amongst the BMW forums as having consistent fit and finish and quality control......said no one ever.
11-10-2020, 11:23 PM | #29 |
Rep 7,591
Pussiwillow521.00 AmuroRay2264.50 |
11-11-2020, 09:19 AM | #30 | |
Rep 4,130
The first one is not unique to VRSF - even CFS had issues with mounting points because the test vehicle was slightly different from the vehicle it was being installed on. The second issue on shipping - not having received any of their products, I can't say how poorly they are packaged. I would be annoyed receiving a damaged product, but to me, that doesn't reflect on how well the part performs. Then again, there are people here who care more about "bling" and "Name" then actual function.
Mods: Yes.
11-11-2020, 03:25 PM | #31 | |
Rep 5,364
On paper, an exhaust, IC, or charge pipe are simply metal parts and pipes with no moving parts. However, the spaces they fit in and things they connect to have very tight tolerances. Also, these parts are also directly connected to things that move and shift during driving thus further complicating tolerances. These tolerances is where the cheaper brands tend to trail the most expensive versions. Like noted above, some are willing to roll the dice and hope for the best. Others may be willing to pay 20%-30% for the peace of mind that the part will likely fit perfectly.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
11-11-2020, 03:54 PM | #32 | |
Rep 7,591
Anyways, I dont think Amuro or anyone else here (on the topic of this thread) was even talking about the fitment of this IC. The discussion was more about the actual performance of the IC, and recently as it relates to other ICs, mostly in terms of IATs. VRSF's reputation is sufficiently known, and I was one of the unlucky ones who got a IC with a cold side connection that was out of spec and it costs me easily 15 hours of removal/reinstall time, research, building boost leak tester, ordering custom orings, etc to get the problem solved. So i am fully aware, but this is just off topic for the thread. |
AmuroRay2264.50 |
11-12-2020, 04:56 PM | #33 |
Rep 26
So... another update. The EVO3 we wanted is not in stock anywhere.. They will make new batch in January. There is the F2x version, which is much more expensive. And even though it might be interesting to give it a try, it is VRSF Race intercooler, that was ordered. Unless there is something really bad with the IC, I do not have fear about the install. The shop is used to improvise a lot, as they built few race (drifting) cars.
11-12-2020, 05:01 PM | #34 | |
Rep 26
11-12-2020, 05:30 PM | #35 | |
Rep 4,130
11-20-2020, 11:36 AM | #36 |
Rep 169
OP - Thanks for the thread and thorough review.
FWIW to other discussion the quality of VRSF... When discussing full bolt-on upgrades with a local BMW specialty maintenance, repair, and performance, shop their opinion was "VRSF is by far the best value. No fitment issues and very good price point." These guys warranty their work for 24 months and are willing to do so with VRSF parts. They've even steered me away from some other more costly companies due to issues they've seen with fit and finish. I guess what I'm saying is you don't always get what you pay for, and sometimes you get more than you paid for. Personal research is key.
2015 F30 335i | Glacier Silver Metallic ///M Sport | Journal
2014 E84 X1 sDrive28i |
Pussiwillow521.00 |
11-20-2020, 12:46 PM | #37 | |||
Rep 7,591
Mostly true, although there are cheaper options now that have a pretty good reputation (i.e., FTP pipes) Quote:
Definitely true, especially the research part. |
silvrbreez217.00 |
01-25-2021, 04:46 PM | #38 | |
2093
Rep 43,350
09-24-2021, 04:25 PM | #39 |
Rep 245
@AmuroRay asked me to measure the fin density.
It's hard to get to, so this is the best pic I could get Hope this helps!
-PCA Instructor #201804533
-B58 F30, 6MT, M Sport, M Perf Exhaust, Dinan Springs, BM3 Stg 1 -My B58 F30 Build Thread https://f30.bimmerpost.com/forums/sh....php?t=1981176 -My F80 Build Thread https://f80.bimmerpost.com/forums/sh....php?t=1757458 -My N55 F30 Build Thread https://f30.bimmerpost.com/forums/sh....php?t=1739248 |
AmuroRay2264.50 |
09-24-2021, 04:45 PM | #40 |
Rep 4,130
09-24-2021, 08:01 PM | #42 | |
Rep 4,130
I know I’m not crazy
https://f30.bimmerpost.com/forums/showthread.php?t=1494948 Quote:
09-25-2021, 01:19 PM | #43 | |
Rep 7,591
12-31-2021, 04:55 PM | #44 |
Rep 183
Thanks for the review. This thread convinced me, vrsf 6.5" ordered!!
can't wait to compare my logs from before/after. I'm happy to read that the lag hasn't increased after the install even with stock tune and turbo. |
