08-03-2021, 12:33 PM | #1 |
Rep 60
Trumpet exhaust after Catted DP Install
Hi guys,
I recently installed a CTS Turbo catted downpipe on my 440i GC w/ MPPS exhaust, and there's a really weird (and annoying) trumpet sound that happens from time to time. It was doing it all weekend, so I took it to my mechanic this morning and of course it stops making the noise. He tightened the clamp and looked around but couldn't find what could be making the noise, but it basically sounded like the video below; We couldn't replicate it, it seems to come and go. Has anyone dealt with this noise after installing a downpipe? I found a post on the M5 forums, but there was no solution unfortunately. Any tips would be appreciated. |
08-03-2021, 02:07 PM | #3 | |
Rep 60
The downpipe was brand new and was installed on Friday (4 days ago). It didn't look used when I received it, and a quick look at the filter showed no damage. I went to stage 2 the day after the install, maybe that possibly damaged it? I was able to tighten the clamps and it's not rattling as much, but it's still VERY raspy. Based on videos I've seen on YouTube, it's not meant to sound like that. Not sure what to do at this point tbh. I don't have a downpipe to compare it with unfortunately. I'll see if I can find a local B58 with a similar setup to compare. |
08-03-2021, 04:41 PM | #4 |
Rep 19
Being brand new has nothing to do it possibly being bad. I have ordered from the NFL and gotten a shirt that was printed way off center. If a shirt can get thru quality control, a downpipe easily can.
08-04-2021, 09:55 AM | #6 |
Rep 60
After tightening the clamps, the sound is almost gone, but you're right, it's the rasp from the MPPSK. It sounds like it's coming from the exhaust, and there's not much I can do about that. There's a small window around 1900-2000rpm where it makes that noise, but otherwise it's gone. Thanks for the help guys.
08-04-2021, 12:28 PM | #7 | |
Rep 163
Shady6747.00 |
08-07-2021, 02:25 PM | #9 |
Rep 4,876
You sure the DP/midpipe isn't rubbing the frame under load? When I did my DP and exhaust, the midpipe was rubbing causing nasty noises until I loosened the clamps and made sure there was clearance.
When you load the engine, it does twist on the mounts which will push the exhaust into the frame if there isn't enough clearance. |
Shady6747.00 |
09-23-2021, 05:07 PM | #12 |
Rep 1,454
He explained what he did several posts up. 🙂
2022 CT4-V Blackwing 6-speed
09-23-2021, 06:31 PM | #13 |
Rep 421
Drives: 2017 F31 328dx
mgeller51.50 alohasurftoad3078.00 |
09-24-2021, 12:50 AM | #14 |
Rep 98
09-24-2021, 08:22 AM | #15 | |
Rep 60
Let me know if you ever find out the solution. |
09-24-2021, 08:56 AM | #16 |
Rep 148
I have a 440xi with cts 200 cell DP (not MPPSK) and it sounds great, nothing like that. To me, it sounds like you have some rattling. Something not clamped on tight. Or it's vibrating against something else. Try replacing the DP, and if that fails you'll have to check the components around it.
mgeller51.50 |
09-24-2021, 08:07 PM | #17 | ||
Rep 98
09-29-2021, 08:20 PM | #18 |
Rep 4,913
Wow. Never heard anything like that before.
12-02-2021, 03:28 PM | #19 |
Rep 20
Any update on this? I have the same issue on my 440ix w/MPPSK and VRSF Cattless DP.
I went back to the stock DP and it got way better, so figured it was the cattless DP. I still noticed it slightly with the stock DP so thought it might be the exhaust rattling on the frame somewhere. I put the VRSP DP back on and installed a spaced on the right cross-member. This helped, but I still get that sound in the same rev-range. I think it might be rubbing on the rear sub-frame, causing the noise. I haven’t had a chance to look at it yet, but that is my hope. I still think I want to go catted DP to tame the overall noise down, but want to get rid of this noise first. |
12-02-2021, 06:41 PM | #20 | |
Rep 98
12-10-2021, 07:12 PM | #21 |
Rep 28
The problem is the CTS Turbo DP itself. Bad design, sounds pretty terrible on my car, with the dinan midpipe and stock muffler it was fairly embarrassing shifting around the 2k mark under load. I swapped the stock midpipe back on and it’s much better but too quiet now. I can’t bother to swap the downpipe again with another but if I did I’d go for ER.
12-11-2021, 08:49 AM | #22 | |
Rep 558
Have a bullet resonator welded into the Dinan midpipe and have it put back in? Replace the CTS DP with another brand and have the Dinan midpipe put back in (no resonators)? If so, which DP? These options would cost another few hundred dollars and there's still no guarantee I'd like the sound. I regret trying the CTS catted DP.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
