08-03-2018, 05:54 PM | #287 | |
Rep 274
Cheers, Tony |
09-02-2018, 01:30 PM | #288 |
Rep 81
I used your script get my E-Sys/Launcher Premium working again on my laptop that I had not used for coding since last year. It worked great! Then I went to code the car and realized that I needed a newer psdzdata, so I got that and then it required me to upgrade from E-Sys 3.26.1 to 3.27.1.
So I uninstalled E-Sys and EsysLauncherPremium, installed E-Sys 3.27.1 and Launcher Premium 2.8.0, run your script, and set date to December 15, 2017. Now I get the "Date Incorrect or date Manipulation Detected" error every time!! I have read this entire thread and tried a bunch of things, including various system dates, creating another admin account, doing a fresh install on a Windows 10 machine with the same installers. No dice. I get the error every time! The laptop is Windows XP, I know it's not supported anymore, but was working fine with your script with the older E-Sys and Launcher versions. I cannot use the latest 2.8.2 version of Launcher Premium as it requires .NET 4.6 and I can't get that for XP. Do you have any ideas ? Am I using an incompatible set of versions? I got the installers from the links posted on the Bimmerfest forum sticky thread. Thanks Tony! |
09-02-2018, 01:47 PM | #289 | |
Rep 141
09-02-2018, 02:03 PM | #290 |
Rep 81
09-02-2018, 06:02 PM | #291 |
Rep 274
First of all, if you're now using Launcher 2.8.2, don't adjust the date but keep it to *today* (as in: the real date that is today). The Launcher should work then. If it still gives you the date manipulation error, then it's probably an XP thing...
The Launcher checks the dates of several system folders to determine whether the date has been manipulated. My guess is that all these folders were fine when you used E-sys 3.26.1, but the deinstallation changed one (or several) of them. My script would normally adjust these dates, but since it doesn't support XP (because XP uses different folder names) not all of your system folders were adjusted, making the Launcher detect your date manipulation. What you could try is first setting the date to today, reboot PC to reset most system folders dates to today, and after that redoing the process of uninstalling E-sys and Launcher and reinstalling them. This -might- reset the date of whatever folder causing the problem also back to today. If it works, Launcher 2.8.2 should proceed without the date manipulation error. If it doesn't, basically you're screwed... (sorry man) Fingers crossed... Good luck! Cheers, Tony |
Jhnblckwood130.00 |
09-02-2018, 07:11 PM | #292 | |
Rep 81
Brad |
10-15-2018, 09:36 AM | #295 | |
Rep 84
anyone shed some light on this. |
10-26-2018, 06:55 AM | #296 |
Rep 15
E-Sys Launcher 2.7.1 inside VM
Hi there, can anybody *confirm* that is able to run this specific configuration:
* VMWare Workstation Player 14.1.2 * Windows 7 x64 SP1 english (as virtual machine) * international Settings setted to en-GB (keyboard, language, timezone..) * .NET Framework 4.6.1 * E-SYS Launcher Premium ver *2.7.1* * E-SYS 3.28.1 Reverting back date to 01-04-2017 and then running your tool, @Tony TwoClicks, I can start E-Sys Launcher but it asks for an activation token. If I revert back date before 19-03-2017 it says "date manipulation".. so I'm sure E-Sys Launcher is starting in the right way, but it want to be activated. If I remove 2.7.1 and install 2.6.2, on the same VM/configuration, E-Sys Launcer starts successfully and E-Sys is working fine. Now, it's clear that VM and settings are ok, I can only think that 2.7.1 has introduced a check for running inside VM environment.. can anyone confirm? Is there a workaround to get 2.7.1/2.8.0 E-Sys Launcher work inside VM environment? Thanks to all. |
10-27-2018, 06:11 PM | #297 | |
Rep 274
Sorry, probably not the answer you were hoping for... Cheers, Tony |
10-28-2018, 04:59 PM | #298 | |
Rep 15
10-28-2018, 05:29 PM | #299 |
Rep 15
Get working!
10-29-2018, 06:57 AM | #300 |
Rep 3
Help needed
Hi! I'm new at the forum so hello everybody It's really nice to be a part of community of bmw owners.
Tony Twoclicks, I have a problem with running your software. When I try to, I've get this info as in attachment. I'm using Windows 10, time is set according to your reccomendations. Antivirus is off. I've checked also on Windows 7 computer with the same conditions. BR Sebastian Last edited by mr.loikes; 10-29-2018 at 08:49 AM.. |
10-29-2018, 11:31 AM | #301 | |
Rep 274
The Self-protection module keeps the ProgramData folder locked, so it must be turned off. After my script has run, you can enable Self-protection again. If you're not running Avast then some other program is keeping a lock on the folder. By browsing it (set Explorer to unhide system files and folders) you may find out which program it is... Cheers, Tony |
10-29-2018, 03:21 PM | #302 |
Rep 3
Thank you for your help. Now it works on one computer. I will search on the another one and will let you know when I realize which program is cousing this problem.
BR Sebastian |
10-29-2018, 04:16 PM | #303 | |
Rep 274
Cheers, Tony |
11-10-2018, 09:38 PM | #305 |
Rep 4
I rolled back to August 2017, install the 2.71 launcher and ran the script. The launcher is asking to activate. What could be the problem?
Edit: It worked after I removed Russian secondary keyboard. Thanks for your work, Tony! Last edited by 3ackok; 11-10-2018 at 10:02 PM.. |
12-03-2018, 12:11 AM | #306 |
Rep 13
repeat EST software Token screen
Hi Tony,
First of all, thank you for creating the script for us. I am having some issues with E-sys launcher program even though i have followed the instructions step-by-step. Can you provide some guidance? I had E-sys launcher premium 2.5.3.108 (i know it's old as i coded car before but I need to recode my car again) I had E-sys 3.27.1, and psdzdata is 3.59.1.003 (again, it's a quite old version) I have successfully changed Window's clock to April 1st 2017, and I have successfully run the batch file 1.6.0 (admin elevated). No error message. Also, EST directory under E-sys 3.27.1 Options/settings is cleared. Now, i launched E-sys launcher premium 2.5.3.108, the program asked me to give a path and passwords. Freetoken.est (under C:data folder) is generated with a date April 1st 2017. However, the screen repeat to ask EST software token path and PIN. I can never pass this screen. I also see alert message:"You will be able to set car series after 48 hours" if I close the E-sys launcher and reopen it again. EST software token screen remains on top. Do you know where I did wrong? Are my software versions too old? Many thanks, |
12-03-2018, 04:59 PM | #307 | |
Rep 274
12-30-2018, 03:58 PM | #308 |
Rep 40
Will this work after today?
I was able to use this on 2.8.2 today (just ran the script and launched it with the current date) but I know the token expires tomorrow. Will this still work next month 2019 ? My question is if it will stop the changes from being written back.
Thanks Last edited by j_internet; 12-30-2018 at 07:43 PM.. |
clock, date, esys, launcher, premium |
