06-20-2013, 09:40 AM | #1 |
Rep 1,053
Will these fit an F30
My apologies for a potentially dumb question as I still do not fully get how to calculate if an offset will fit.
Will these offsets work on the F30? They are e46 M3 CSL wheels 8x19 ET:47 Front, 9.5x19 ET:27
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
06-20-2013, 10:15 PM | #2 | |
Rep 3,205
e92 ///M3 |
06-21-2013, 05:22 AM | #3 |
Rep 944
^^^^^^^^^ what he said. They won't just bolt on but with work and spacers they might
2013 Alpine White 328I M Sport ARRIVED
06-21-2013, 06:16 AM | #5 | |
Güten Täg
Rep 161
Technically they will fit, but will be ~10mm too far out in the rear.
2013 F30 328i Sport 6MT MG
1991 E30 318iC 5MT M20B25 swapped Vert Black - gone |
06-21-2013, 08:18 AM | #6 |
Rep 1,053
Thanks all, so staggered 193s (i'm not sure the offsets but I know they are the same as the 189s, 162s, etc from the e9x), will be about 10mm (or would it be a half inch?) more tucked in at the back but the same in the front (i.e. need 10mm spacers)?
Current: 2021 340xi
06-21-2013, 08:46 AM | #7 | |
Dinosaur supervisor
3030
Rep 4,214
The 193's will be about the same as stock F3x wheels up front and a bit more (10mm) aggressive in the rear compared to stock. |
06-21-2013, 09:11 AM | #8 | |
Rep 1,053
Thanks for the info! So that might be a pretty solid look as I personally think the rears need spacers more than the fronts. As to the comparison, I was asking about those M3 CSLs compared to the 193s, so: 19x8 et 47 front; 19x9.5 et 27 rear versus 18x8, et 34 front, 18x8.5, et 37 rear Sounds like those M3 CSLs are just too far off, they are really cheap from tischer and I just thought there might be a chance they'd work.
Current: 2021 340xi
06-21-2013, 09:31 AM | #9 | |
Dinosaur supervisor
3030
Rep 4,214
I usually use: http://www.1010tires.com/Tools/Wheel-Offset-Calculator |
06-21-2013, 09:38 AM | #10 | |
Rep 202
Matt |
