BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > oil extraction pump
      09-19-2020, 12:49 PM   #1
RJR82
Drives: Bmw 318d
thought i would share,
done an oil change on my 2013 318d today,
got myself an el cheapo 12v oil extraction pump from amazon about £15 and what a time saver,
i know not all all of you will like the idea but it made it so much easier and quicker!
didnt need to jack car up or lose the sump plug in hot oil lol
3-GT43.50
      09-19-2020, 12:58 PM   #2
Watsey
How much oil did you get out ?
Current : F31 330sD, DMS remap, XHPflashtune, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech Trophy front BBK / MSport rear discs and calipers, Pagid RSL1 pads all round, H&R/Eibach ARBs, Michelin P4S.
      09-19-2020, 01:09 PM   #3
RJR82
Drives: Bmw 318d
i measured what was pumped out by using a litre jug and just tipping into a bigger bucket when filled , just incase, and got out what seemed to be about 5.4 litres
which is weird as its suppose to be 5.2, but obvs the jug method isnt 100% accurate,
but happy that i got all of it out!
      09-19-2020, 01:18 PM   #4
Eddamoo
Drives: BMW 430dX
I use a suction pump for my interim changes. Did a little test with mine and got the same out as I would the sump method, certainly within 30ml. I do spend a few minutes fiddling with it to get the most out
The suction pump can be used to pull oil out of the filter housing which must be around the same as what it misses in the sump. Its quite a lot!
      09-19-2020, 01:31 PM   #5
RJR82
Drives: Bmw 318d
when i released the filer housing and filter you could hear a few hundred ml pour down,
so just turned the pump back on pushing and pulling the tube to get last out like you said,
sounded like a cheap prozzie sucking on your bellend hahaha
      09-19-2020, 01:36 PM   #6
3-GT
Wales
44
Drives: BMW 320d GT
I'm planning to change my oil at 50% what is recommended, a pump would be ideal for this. Got any links to the ones you've used?
      09-19-2020, 01:41 PM   #7
RJR82
Drives: Bmw 318d
just search amazon or ebay might be cheaper
oil extraction pump, got 2 tubes pump body and crocodile clip connections
      09-19-2020, 02:35 PM   #8
bishbosh
Drives: F30 335d
2014 BMW 335d  [0.00]
That's why I do the filter change first, then suck the oil out. Although I have a manual Pela pump. The electric one sounds great, could have a cuppa while you wait
      09-20-2020, 12:42 AM   #9
Soul_Glo
Soul_Glo's Avatar
Drives: 320d G20
Photos and DIY walk through... but good to hear you got it done.
Just let your soul glo...
      09-20-2020, 02:59 AM   #10
Stainy
Drives: 435d M Sport Xdrive
As if by magic, LIDL answer the call this Thursday
3-GT43.50
      09-20-2020, 07:39 AM   #11
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
where did you extract from? I have one that I used on my old cars, but it went through the dipstick tube.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
      09-21-2020, 12:47 AM   #12
RJR82
Drives: Bmw 318d
exactly that
push the hose down the dipstick tube, connect pump to jumper points, and off you go,
pumped all of the oil out in under 5mins
      09-21-2020, 05:26 AM   #13
Sasquartch
Drives: 520i G30
Good idea....unless you have a petrol which has no dipstick
      09-21-2020, 08:00 AM   #14
paimon.soror
^ ah, that would do it. I was gunna say lol ...
      09-21-2020, 05:54 PM   #15
dholdi2
Drives: F31 35d
Or a diesel which also doesn't
      09-21-2020, 06:10 PM   #16
bishbosh
Drives: F30 335d
Which diesels don't have a dipstick?
      09-21-2020, 06:51 PM   #17
dholdi2
Drives: F31 35d
I didn't think mine did, unless you are telling me otherwise ?
If so then I should have
      09-22-2020, 12:48 AM   #18
BBri89
BBri89's Avatar
Drives: F31 320d xDrive M Sport
It's hidden pretty well but my N47 has a dipstick.
I thought they all did, but they're just not easily visible at all.
It's right at the back of the engine I think, near the firewall and almost completely obscured by the plastic engine covers?
2015 F31 320d xDrive M Sport (Plus pack)
My progress thread
      09-22-2020, 03:03 AM   #19
shoestring
Drives: 2017 F31 320D Sport Auto
I just don't understand why anyone would not just do the job properly and drain the oil via the sump plug!
It is not that much of a bother and ensures that all old the old oil and any gunge that may have accumulated in there is removed.
      09-22-2020, 03:15 AM   #20
bishbosh
Drives: F30 335d
The dipstick pipe is located over the lowest part of the sump, so sucking the oil out will get most of it out. Even if you drain via the plug, there would still be a coating of oil in the sump anyway.
And using a pump, manual or otherwise makes for a cleaner/quicker job.
if I've helped - an Appreciate would be, er, very appreciated!
      09-22-2020, 06:11 AM   #21
LukaUK
Drives: BMW F31 335d Xdrive
Well its messy, you need to get under the car, not every one has a jack. On F31 335d its super easy with an extraction pump as engine has a dipstick and filter housing is accessible from the top. Its 15 min job tops.
I agree, on cars that have filters accessible from underneath the car it makes sense to drain as you are going under anyway.
Also, if any gunge accumulates in the sump then I suspect oil changes are not frequent enough.
      09-25-2020, 03:15 AM   #22
p-dawg
Drives: BMW F30 330D MSport
Lidl had plenty of them in stock yesterday. I picked one up, not bad for a tenner. Hopefully it will make the job of doing oil changes easier as i do it quite regulary on my car.
