BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      07-19-2020, 10:37 PM   #1321
Devil doc
Drives: M240ix
Originally Posted by eeee36M3 View Post
Hi,
Looking for feedback on my log.
2016 340xi
AA catted downpipe stage 2 91
I have “not high grade” 93 octane.
I was running stage 1 93, but noticed some knock detects, so I swapped in 91 tune for stage 2, but still see knocks.
I’m still trying to learn the logs. I think the timing doesn’t look great? Maybe new plugs would help? Should I run the colder/gapped ones I see comments about? I have 40k on the odo.
Thanks!
https://www.bootmod3.net/log?id=5f14...0b43706d8b4762
I had the same issues too. I have a catless AA DP and the Stage2 Ots map in both 91 and 93 were pulling lots of timing. Im in fl so we have 93 gas. I actually flashed back to stock and that helped a bunch. I’ll likely add a little E to see if It’s an octane issue
This was the 93 ots map (Stage 2)
https://datazap.me/u/devil-doc/m240i...37-38-39-40-44
This was the 91 Ots map (stage 2)
https://datazap.me/u/devil-doc/mhd-s...40-41-42-43-47
This was after I reflash the stock map.
https://datazap.me/u/devil-doc/stock...-47&zoom=2-105
      07-19-2020, 11:11 PM   #1322
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Hi,
2016 340xi
Thanks!
If you haven't changed your plugs at 40K you should, but I don't think that'll help your timing, only less boost and/or better fuel.
If you can't or don't want to use better fuel maybe consider a Stage 1 91 tune?
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
      07-20-2020, 12:47 AM   #1323
alpinweiss340
alpinweiss340's Avatar
88
Drives: 340i
Hey guys was wondering if someone can look at this log I did. (Previous one I posted was a third gear pull this is a fourth gear)
I had a problem with the wastegate rattling last week. Tried to tighten it and ended up throwing a check engine/drive train malfunction/limp mode. I tried my best to adjust it back to where I thought it was before. When I started it in the morning no check engine was on, drove like a grandma for three days, until I decided to do a little pull before the log and it seemed semi decent. (I made a appointment with a local shop to check out the wastegate on Wednesday) Not sure if it’s all in my head but I think something might be slightly off. (Spark plugs gapped to 0.022)
https://www.bootmod3.net/log?id=5f15...90c66625c37ee6
Thanks guys
*ps. Low end feels fine to me, mid to high seems to fall flat?
      07-20-2020, 02:58 AM   #1324
Sgm123
Drives: Bmw
Do you need to gap plugs for a small amount of e85 then or is stock fine. Only replace them 4K ago so ideally don’t want to touch
      07-20-2020, 03:27 AM   #1325
alyabiev
Drives: BMW M3 Competition Touring
Thanks guys
Ignition timing advance profile looks really bad. Cat meltdown in 3, 2, 1.. What octane are you using?
      07-20-2020, 03:45 AM   #1326
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
Stock gap for plugs is fine up to and including straight E85 with stock turbo
      07-20-2020, 03:48 AM   #1327
alpinweiss340
88
Drives: 340i
91 octane, in California.
Catless DP.
Any advice? What do y’all think is causing it? Would installing the stock plugs be beneficial?
      07-20-2020, 04:15 AM   #1328
Eldotbe
Drives: M140i
Want to run meth, what’s the best way to go about that. Do I buy the bms meth kit and then buy a JB4 and run their wmi map along side bm3/mhd. Or is it better to get a custom tune to intergrate the wmi, what’s safer and advantages and disadvantages for both?? Thanks
      07-20-2020, 04:21 AM   #1329
IMS-340C
IMS-340C's Avatar
Egypt
395
Drives: Self Tuned 340i 8AT RWD
Are you now maxing out the stock turbo ? or you you think there's still more in it ?
Originally Posted by OzBMR View Post
Here's the log from a 7.02s 100 - 200 run using the MHD Stage2+HPFP and E42 fuel, Dorch Stage 2 HPFP.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT --------
      07-20-2020, 04:28 AM   #1330
OzBMR
OzBMR's Avatar
575
Drives: BMW M140i
In cooler weather there is probably a bit more, especially if I further increase ethanol, but not in hotter months here.
IMS-340C394.50
      07-20-2020, 04:35 AM   #1331
N420i
Drives: 2016 420i lightly modded
since timing pulls seem to happen to 90% of us running OTS maps with straight pump gas, and engines don't seem to be blowing up all over the place, should I assume that the OTS maps are safe even with the timing corrections?
      07-20-2020, 09:01 AM   #1332
eeee36M3
Drives: E36 M3, 2016 340xi
Thanks for that reply, this is what I was thinking of trying as well. It's interesting you have different SW (MHD), and still see similar results that I have. I guess it's not a BM3 only issue. I was going to try to run higher octane, or try to find some octane boost to dump in. I haven't looked to see the best way to try it yet.
Do any clean logs exist for B58 motor that do not pull timing? Seems like even stock tunes have some amount of pull. Trying to get a feel for how much timing pull is too much, etc... I've heard the E30 maps work well (I don't have E30 near me), but I wonder what the timing looks like. I'll try to find one.
      07-20-2020, 09:42 AM   #1333
alyabiev
Engine won't blow because timing WAS corrected and the amount of correction is learned over time. But exhaust valve seals and stems, headers and cats can melt away with time
      07-20-2020, 10:40 AM   #1334
340iNL
Drives: G81 M3 Competition '23
Do you mean the valves and stems of our engines (in the cylinder head)?
Won't be funny to replace them I guess that's an 2.000 euro job.
      07-20-2020, 10:55 AM   #1335
vladyslav-r2
Ukraine
Drives: 240ix
24 PSI is a lot of boost, check your charge air temp it would definitely be very high.
Near 150-160C
      07-20-2020, 11:19 AM   #1336
M140_BCS
M140_BCS's Avatar
238
Drives: 440i Gran Coupe
Hi OzBMR
Please could you plot the virtual dyno on this log.
https://datazap.me/u/m140bcs/log-159...og=0&data=5-23
440i Gran Coupe RWD - ZF8
Thanks.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
      07-20-2020, 11:23 AM   #1337
alyabiev
Yeah, this is due to excessive ignition retard when most of combustion happens on the exhaust stroke. DME has a failsafe for that - forced load reduction if EGTs are over a certain limit. The question is: had tuner left that limit intact or raised it to allow all of the performance at any cost.
Kirill @ OdinTuned
      07-20-2020, 11:27 AM   #1338
alyabiev
Originally Posted by M140_BCS View Post
Hi OzBMR
https://datazap.me/u/m140bcs/log-159...&data=5-23
Thanks.
I think there is no way to plot that log correctly - RPM values look glitched somehow.
Kirill @ OdinTuned
OzBMR574.50
      07-20-2020, 12:29 PM   #1339
M140_BCS
M140_BCS's Avatar
238
I've checked the 4 logs I did yesterday and they all have rpm glitches??
      07-20-2020, 12:43 PM   #1340
IMS-340C
IMS-340C's Avatar
Egypt
395
What fuel are you using ?
Originally Posted by vladyslav-r2 View Post
I am also have a problem with IAT.
Amb. temp. 22C (at night), IAT at the 24PSI 55C
M240IX Pure800, Dorch Stage2...
Near 150-160C
      07-20-2020, 12:57 PM   #1341
N420i
Well according to BM3, their OTS tunes have left all the factory safety measures in place, but limiting power to 340hp is a safety measure soooooo...
      07-20-2020, 01:00 PM   #1342
N420i
These logs that M140_BCS just posted seem to have pretty f'n impeccable timing...
According to his signature he's only running DP and HPFP on straight 98RON pump gas
Logs were taken with 11ºC ambient temperature and IATs are therefore suitably low at around 22-25ºC though.
