BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
      09-24-2021, 08:50 AM   #485
Ruse
Drives: BMW F34 335d 2015
Finaly I screwd up my NAVI. After entering the wrong FSC three times the NAVI is asking for the FSC from of the old MAP. No way to know them.
Is there a way to download the DE file from the car, in order to generate the FSC for the new Map Euro West next 2022-1 or 2022-2.
I don't have E-sys. possible I've to look for it?
Tks for help
Driving without NAVI is sometime a pain in the .....
      09-26-2021, 05:50 AM   #486
geron1
Reupload/Mirror OSX version:
v.1.9.1
WeTransfer: https://we.tl/t-JSyAJswncT
ZippyShare: https://www56.zippyshare.com/v/HsKGyqur/file.html
MEGA: https://mega.nz/file/ELx2iDbK#FuQ-HG...CKvMqemMNfR2vA
Keep in mind that MacOS Big Sur and Catalina will throw an error: "You don't have enough permissions to open the application"
Here's a potential fix but I haven't tested it because I've been using Windows for BMW stuff.
Remember to revert that fix once you're done with that generator because it's not safe to have it disabled.
      09-27-2021, 12:32 PM   #487
bleron13
Drives: bmw 530d f10
hello can you update please lookup.xml for new maps ?
Europe West PREMIUM USB 2022-1
Europe West NEXT 2022-1
      09-30-2021, 02:06 AM   #488
geron1
You can add new maps by yourself:
https://f30.bimmerpost.com/forums/sh...1&postcount=89
      09-30-2021, 02:16 AM   #489
Siki78
Siki78's Avatar
136
Drives: F30,G30
Tks for help
If you have enet cable i can help you to pull out fsc and generate right code
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      10-01-2021, 02:02 AM   #490
PKuncik
Drives: BMW F07
      10-04-2021, 11:32 AM   #491
Ruse
Tks a lot, everything works fine. Installation of new Map successfully
      10-04-2021, 05:13 PM   #492
PILKO
Drives: BMW f31 335d
Looking for help
I have attempted to upload the entry europe west 2020-2021 maps. I put the activation code from the generator in but neither the lifetime nor single fsc worked. Satnav now asks for a code, even for my original 2015 2a but I don't have it.
I have connected the car to esys via enet cable and followed the instructions on the forums to read the fsc however it shows as not activated now.
Could someone either guide me how to recover the original fsc or get the fsc for the new 2020 maps. I only have the centre usb so file 1b is not an option from glovebox and I cannot create file from esys as an error occurs when I read and store FSC due to there being no code present.
For info, Vin is K468748.
Currently 2015 2a Entry
Looking to update to Europe west 2020-2021.
I am sure it had been covered before but I am struggling finding an answer
      10-05-2021, 03:58 AM   #493
zco
Drives: F30 316i
I could not work it at Big Sur! Anyway thank you for the files 👍🏻
v.1.9.1
      10-05-2021, 01:48 PM   #494
gunnersz
Romania
Drives: BMW 320dxdrive
Originally Posted by PILKO View Post
Looking for help
same problem here, but i only entered the code once and now it asks for the activation code of my navigation
      10-06-2021, 03:40 PM   #495
PILKO
Could anyone send me a lifetime activation code for my 335d running Entry satnav. Looking to put new code in to rectify the aforementioned question. Was going to order through Ebay but with FSC codes now not activated, worry I am throwing good money to a bad problem
      10-12-2021, 03:20 AM   #496
gelo102
Drives: BMW 318d
Hi everyone,
I was trying every Thing to find Code for my maps West 2022-1
This program not working On Windows, can somebody help my Code
Finden?
F832931 bmw f31 Touring 318d
I was also try with another but not working by me, i Dont have Index 00DE
      10-12-2021, 09:15 AM   #497
freseman
Drives: BMW 328I
Thanks a lot for the info
      10-13-2021, 06:38 AM   #498
PILKO
I eventually ordered the FSC lifetime code off Ebay along with the 2022-1 entry maps (£27) total, from leadsinger_1971..
Although I had lost my FSC from the ECU, code and install worked fine.
I know it's a cost but less hassle than fiddling around with computers etc.
Hope this helps someone who has had all the FSC codes marked as rejected.
Satnav all up to date and working like a dream
      10-17-2021, 02:48 PM   #499
AleksaMilovanovic
Drives: BMW F10 520d
Hello, i've read the whole topic, but didn't understand totally the proces. Also not so tech wiz. ��
If someone could help me, with sending me the codes for my cars.
I have a F10 NBT with Europe Next 2013 going to Next 2022-1, chasis: D265430.
Also F25 with Europe Premium 2011, but I also need link for latest maps, chasis L553275.
      10-22-2021, 08:14 AM   #500
ckpe
Denmark
Drives: BMW 320D F31
Originally Posted by PKuncik View Post
Hi
I have looked a lot at bimmerpost but can not find any new FSC code generator that I can download, also can not just find any new Maps.
Do you have the opportunity to send me a link?
I have EUROPA EVO 2019-3 now and NBTevo_S19322I
Thanks in advance and sorry for the inconvenience 🙂
Regards Carsten
      10-22-2021, 08:25 AM   #501
Siki78
Siki78's Avatar
136
Drives: F30,G30
I can`t send you PM.First time you have more then 4 post write me on PM
      11-01-2021, 08:02 AM   #502
H4s4N
Denmark
Drives: BMW 520 F11
Does it work for retrofitted units? I have a F11 from 2012, and retrofitted CIC with big screen. I think I have premium map from 2019. which method can I use fro update my maps to the latest? are there same thread with some guidance?
Thanks for advise.
      11-04-2021, 02:30 AM   #503
Ammuliu56
Drives: Bmw e90
Hello can anyone help me with a fsc code for east europe premium 2022 maps.
WBANX31000C385590 This is vin code.
      11-05-2021, 11:55 AM   #504
Aybi1903
Drives: BMW F34 320D
where can I find the maps 2022?
      11-05-2021, 12:40 PM   #505
Ammuliu56
Drives: Bmw e90
East europe
https://mega.nz/folder/234QFJiY#PZJTdG-fYxdhGEvSD9R3Ng
West europe
https://mega.nz/folder/Hi52XZra#q2qb3isx2higb9JxQSJW4w
      11-05-2021, 03:02 PM   #506
aidbar2
Drives: BMW E90
How I can get FSC generator?
Thanks!
