07-18-2018, 08:45 PM | #1 |
Rep 234
Stuff I can't find in the owner's manual!!
1. Wheel torque. I found a figure on this forum of 103 ft lb for the 2016.....I'm assuming that it's the same for my 2015 regardless of which wheels it has.
2. Where's the oil filter and drain??? 3. What's the oil capacity of the 335i's 6 cylinder engine. 4. Looks like BMW does not recommend tire rotation. True? 5. xdrive....... Can't find a word about it. No buttons, no indicators, only a label on the trunk!!! What did I miss?? Your knowledge is appreciated..... Bob
2015 Mineral White 335xi Sport trim
07-18-2018, 08:49 PM | #2 |
Rep 16,079
The owners manual is quite vague on DIY maintenance, as it's something few owners do. Google what you want to do, you'll find a youtube video how to it.
There are no buttons or indicators for xDrive, the system is totally automatic. |
07-18-2018, 11:00 PM | #3 |
Rep 3,871
1. 130 Nm. That information is included in my user manual.
4. I have read something about it somewhere in the manual. It is not recommended for Xdrive 5. There is a video about it in the interactive user manual. Apart from that - nothing in the car itself. Fully automatic and no status screen as on some X models.
rackjuediger143.00 |
07-18-2018, 11:08 PM | #4 | |
Rep 808
Oil capacity 6.5L Drain plug, the only 17mm bolt that's visible on th undercarriage. There's a hole in the belly pan. Oil filter, buy a specialized oil filter wrench don't gouge the thing up with one of those 'one size fits all' ones Tire rotation is fine if all wheels and tires are the same size, not often the case from OEM |
07-18-2018, 11:13 PM | #5 |
Rep 2,499
1. F30 wheel lugs are 104 ft-lbs I believe. I just tighten them to about 102 ft-lb. Honestly, there is a lot of wiggle room with wheels. You can probably go as high as 120 ft-lb with zero issues.
2. Oil filter is in the engine bay under the hood. It's a cartridge type filter. Easiest oil change you'll do. Just remember to replace the gaskets. All decent oil filters will come with 2 new gaskets. The oil filter is housed in the black plastic round piece on the near right side of the engine close to the front. Oil drain is under the engine. There's a small access panel you can open. Can't miss it. There's one drain bolt there. 3. Oil capacity of the N55 is approx 6.5 quarts. I always fill to 6 quarts, run the engine oil measurement routine in iDrive, and fill up according to the gauge there. 4. You can rotate if you have a square setup. They don't recommend rotating because many cars are staggered. I believe many xDrive models are square so you can probably rotate. Just make sure your tires are all 225 width. 5. The xDrive system is a permanent AWD system. You should be able to see your front half shafts if you peer down the driver's side between the engine and strut tower. BMW's system is RWD biased and there's really nothing to adjust. The transfer case is connected between the transmission output and drive shaft. |
Digital_83262.00 |
07-19-2018, 06:31 AM | #6 | |
Rep 234
07-19-2018, 06:36 AM | #7 |
Rep 234
We have oil cap answers of 6.5 L and 6.5 Qt. Those amounts are 5% apart!! What is the source??
07-19-2018, 07:03 AM | #8 |
Rep 234
Where can we find torque settings listed? Should know the oil drain plug and filter cap specs as well.
07-19-2018, 07:59 AM | #9 |
Rep 16,079
Use this: https://www.newtis.info/tisv2/a/en/
eleven11371.50 |
07-19-2018, 08:53 AM | #10 | |
Rep 234
07-19-2018, 09:34 AM | #11 |
Curmudgeon and Pedant
690
Rep 3,489
You might also look at this thread: https://f30.bimmerpost.com/forums/sh...ne%2C+give+one
07-19-2018, 11:49 AM | #12 | |
Rep 2,197
3610 Overview of tightening torques Wheel bolt M14 - 140Nm After installation, torque of all wheel bolts must be checked again. Wheel bolts must not be oiled! Wheel bolts M14/AF 17 - 140Nm Screw in wheel bolts and evenly tighten crosswise by hand in order to centre the wheel rim. Tighten wheel bolts to the prescribed tightening torque with a calibrated torque wrench in a crosswise sequence. Check all the wheel bolts in the same order or retighten to the prescribed tightening torque again.
07-19-2018, 12:14 PM | #13 | |
Rep 2,499
Thanks. |
07-19-2018, 06:05 PM | #14 | |
Rep 153
It is 6.5L, which is just under 7 US liquid quarts (6.86847Q to be exact ). And I do the same as you - refill using 6 quarts, then use the oil level function in iDrive to add more and get up to the "Full" mark. Last edited by VCuomo; 07-19-2018 at 09:43 PM.. |
07-19-2018, 07:51 PM | #15 | |
Rep 2,499
https://www.ecstuning.com/b-genuine-...h/71126769683/ Part 71126769683 |
07-19-2018, 10:45 PM | #17 | |
Rep 234
07-19-2018, 11:23 PM | #18 |
Rep 2,499
Most 3/8" torque wrenches don't go up to 100 ft-lb. You usually need a 1/2" torque wrench for lugs. Considering accuracy isn't exactly critical for wheels, you can just get by with a cheaper $20 clicker just for wheel duty.
07-20-2018, 05:55 AM | #19 |
Rep 134
Drives: 2017 f32 440i coupe
I didnot have torque wrench just tight wheel to how much i feel alright. And wheels stay on with no porblem for year.
07-20-2018, 06:17 AM | #20 |
Rep 234
Just check your nuts and make sure they don’t fall off!!
