10-20-2021, 11:00 PM | #199 | |
Rep 1,199
10-21-2021, 10:39 PM | #200 |
Rep 1,199
Bought the codes last night. Will probably flash Saturday morning. Is everyone pretty much doing this on battery? I was thinking of trickle charging overnight with a tender to peak it out and give that little extra assurance. I know the car leaves the battery around 80%.
10-22-2021, 06:12 AM | #201 | |
Rep 122
Will post adaptation values tonight.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
10-23-2021, 04:29 AM | #202 | ||
Rep 122
Car has done 37k km's. About 7k with Pure 800.
10-23-2021, 05:58 AM | #203 |
Rep 3,860
All absolutely within normal range.
Uni-Rapide71.00 |
10-23-2021, 10:16 AM | #204 | |||
Rep 1,199
Uni-Rapide71.00 |
10-23-2021, 03:05 PM | #205 |
Rep 1,199
Just flashed Stage 3 with no additional options. Haven't driven it yet and probably won't get over the recommended 50 or so miles before about Wednesday.
I highly recommend doing it with an ENET cable and Ethernet adapter for iPhone. It took less than 2 minutes for the initial flash so battery was not a concern at all.
Uni-Rapide71.00 |
11-25-2021, 03:18 AM | #206 |
Rep 3
I just installed stage 2. Sport mode disappeared. Before the gearbox never allows less then 2k rpm in Sport mode. That allowed to accelerate immediatelly without downshifting. Now there is no difference in Comfort and Sport mode. Rpm 1.2k when driving steady in Sport . I'll try the stage 3, if no difference will back to stock.
11-25-2021, 03:50 AM | #207 |
Rep 3,860
I am not an xHP user yet, but please note the following change of logic by xHP:
https://www.xhpflashtool.com/blog/ho..._logic_of_8hp/ I assume you read the product description and FAQ before purchasing....
11-25-2021, 10:50 AM | #208 |
Rep 3
The shift speed is different in sport mode and comfort mode for the stock map. There is no need to install xHP maps for this purpose. This is how the stock map works: soft and slow shifting for comfort and faster / stronger shifting in sport mode. The problem is that xHP maps remove sports mode. For the stock map, in sport mode, the gearbox keeps 1900 rpm or more, allowing you to accelerate instantly. After installing xHP maps, the sport mode looks like the comfort mode. Driving with 1100 rpm in sport mode is not what I expected from tuning maps.
11-25-2021, 11:14 AM | #209 |
Rep 3,860
Did you care to read the link I posted…?
01-22-2022, 12:14 PM | #210 | |
Rep 1,199
Our Stage 2 calibration follows a simple rule: The gear lever changes the Shift-Points, while the DEC changes your Shift-Speed.
01-25-2022, 04:50 PM | #212 |
Rep 558
When I got xHP, I flashed stage 3 (v1.7) with some custom settings and have been using it since without issue.
I recently got a new phone (Samsung S20FE, Android 12). I wanted to adjust some of the custom settings. I logged into the app on my new phone and connected to my MHD black wifi OBD2 adapter. So far, so good. However, when I try to adjust the settings for flash, I get a message saying that the xHP app wants to save the current settings, but it can’t connect to the internet. So, I can’t continue. I am connected to the MHD wifi adapter (no internet) and I have the phone's mobile data connection on. But, it seems the app won’t use the mobile data because it is connected to the MHD wifi (no internet). I tried setting the xHP app to use “mobile data only”, but then it won’t connect to the MHD wifi adapter. So, I can’t flash, because I can’t save the current settings… Any ideas how I can get the xHP app to use mobile data, while connected to the MHD wifi adapter? I emailed xHP, but while I'm waiting for a response, thought I'd post here to see if anyone else has run into this. Edit: I got a response from xHP. It was simple. The app (on the new phone) hadn't yet downloaded all the content. So, all I needed to do was select the car, adjust all the settings and save, while connected to the internet and BEFORE connecting to the MHD adapter and car. It's usually something simple and stupid. DOH!
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
01-31-2022, 09:06 AM | #213 |
Rep 3,860
There are plenty of reviews and impressions from xHP... I read and watched probably most, but now that I finally pushed the trigger and installed xHP, I realised how off one's expectations can be despite, or even because of, all the reading/watching
So to all of you who have already read and watched xHP reviews, here are a few bullet points about what I (and that's just me) found surprising when I finally installed it. Maybe it will be useful to some of you, especially those hesitating. Note: These are first impressions only. I am still in the early testing phase, did 100km warm-up adaptation as required followed by about 50km of testing in various modes, Stage 2 and Stage 3.
Overall I was concerned the xHP software may be lacking sophistication and maturity, but it looks like it rather has more of that than the stock! I do like the increased versatility of the modes a lot. I always felt it is too subtle with the stock software. xHP subjectively feels more as a more intelligent reorganisation of features and modes the gearbox always had, rather than a "tune" which pushes boundaries. Yes, there are optional modes and features you can use to push it further, but that's left to the user. The basic setup feels like a further development of the original gearbox software, improving every mode, whilst not ignoring what each mode stands for. I am very happy to see that.
PeterWT252.50 scott6015818.50 |
01-31-2022, 02:58 PM | #214 | |
Rep 187
It’s exactly what I think. Very good write-up ! |
Skyhigh1879.00 |
01-31-2022, 04:02 PM | #215 | |
Rep 558
I would just add that it makes me feel good knowing that, considering my stg2 ECU tune, the increased torque limits are there.
01-31-2022, 06:04 PM | #216 | |
Rep 4,871
01-31-2022, 09:37 PM | #217 | |
Rep 1,199
It doesn't quite act how they describe but still an improvement overall. Biggest complaint for me is that I've triggered a big clunk before that felt and sounded awful. I know how I did it so I can avoid it. Similar pedal play would clunk the shit out of a manual too so no big deal. Second complaint would be downshifts with stage 3 are too aggressive and they lurch the car forward at lower RPM. But low RPM isn't the intended use of that mode so hard to really complain. I'll probably back the blip off by 5-10% to reduce some of that.
02-01-2022, 04:38 AM | #218 | |
Rep 3,860
Isn't that something one can adjust under "Throttle Blips M-mode" for 2 --> 1 specifically? Aren't there throttle blips in Stage 2 Manual as well? Also talking about Manual mode as well or generally? Sport+ only?
02-01-2022, 07:17 AM | #219 | |
Rep 4,871
Easy test is start coasting to a light, and manually downshift. It doesn't do it in stage 2 though so I went back to that. |
02-01-2022, 10:48 AM | #220 |
Rep 82
The XHP trans tune is just awesome. You can stay in grocery getter mode (D) or go to race car mode in sport, adjustable blips to boot, and shift points. Best of both worlds.
