      07-27-2013, 05:27 AM   #4137
thebadboy
Drives: 335i f30
It is not possible with CIC. Only the new NBT Head Unit can have different Logo's.
ha damage, it is not possible to activate the menu (file) NBT
      07-27-2013, 05:50 AM   #4138
shawnsheridan
shawnsheridan's Avatar
No. You need NBT Head Unit.
      07-27-2013, 09:35 AM   #4139
m3kidd
Drives: 13' F30 328i / EK Civic
Hi, I've just downloaded the BMW_E-Sys_3.18.4_47.5, will this work for my 2013 F30? I'm also about to order the cable from ebay, any suggested sellers? Planning to code mine and my friends 335.
      07-27-2013, 09:44 AM   #4140
shawnsheridan
Good luck with that.
BMW_E-Sys_3.18.4_47.5 is way too old for a 2013 car.
You most likely will need 49.4 PSdZData, which also means you will need E-Sys 3.22.5 and Patch / Token.
You can get ENET cable here:
User April1:
http://enetcables.com/
One-Stop Electronics:
Ethernet to OBD2 cable (ENET) - 1.8 meters
http://www.one-stop-electronics.com/...&product_id=21
      07-27-2013, 09:52 AM   #4141
m3kidd
Thanks for the info. Any links to the new software or possibly PM me where to get it?
      07-27-2013, 09:53 AM   #4142
shawnsheridan
PM sent.
      07-27-2013, 11:50 AM   #4143
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
665
Drives: 2020 G20 320i M Sport
Does anyone know if the dealers are using anything higher than 49.4 now? I'm taking my car in for service for two recalls in August and I'm worried that I won't be able to code my car again with 49.4.
      07-27-2013, 11:57 AM   #4144
thebadboy
Drives: 335i f30
hello, I coding my brother's car, all worked. but now I get to have more than one connection on my car. why?
      07-27-2013, 03:14 PM   #4145
shawnsheridan
Maybe...50.0 was pushed out, at least to some dealers, but it had problems, so the ones I talked to are still using 49.4, and waiting for 50.2, which is due next week.
I would wait until your dealer has 50.2, and then get it programmed. Don't worry about 50.2 PSdZData. I will have it the same day or next after it is pushed out.
      07-27-2013, 03:15 PM   #4146
shawnsheridan
What do you mean by "get to have more than one connection on your car"?
      07-27-2013, 04:01 PM   #4147
thebadboy
Drives: 335i f30
when I run ZGW SEARCH, I have no connection, the PC no longer wants to connect to the car.
I think a problem has an IP address, but I'm not
      07-27-2013, 05:58 PM   #4148
shawnsheridan
Have you tried making connection to the car anyway, regardless of ZGW_Search?
      07-27-2013, 06:50 PM   #4149
thebadboy
Drives: 335i f30
do not ask me why, but doing nothing all work again
thank you anyway
      07-27-2013, 07:32 PM   #4150
steve@codemybimmer
Hong Kong
665
      07-28-2013, 05:02 AM   #4151
thebadboy
Drives: 335i f30
hello, how to restore a CAFD file, restore the original I save the first time thank you
      07-28-2013, 09:43 AM   #4152
shawnsheridan
You do not need to restore it from original read .ncd file.
Just VO Code the ECU with original FA (VO), and it will be reset.
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
      07-28-2013, 10:06 AM   #4153
thebadboy
Drives: 335i f30
I find page 17, here is
http://www.f30post.com/forums/attach...7&d=1342285494
I encode the rear camera, but after a certain tempnelle turns off. how thank you
      07-28-2013, 10:08 AM   #4154
shawnsheridan
I find page 17, here is solution>http://translate.googleusercontent.c...tUnE59bkvR9WXw
Read VCM does not restore anything.
What is it you are trying to do?
      07-28-2013, 10:49 AM   #4155
thebadboy
Drives: 335i f30
CAFD the file was corrupt, ffffffffff. I followed the procedure and everything works. for a rear camera ideeb.
Thank you
      07-28-2013, 10:50 AM   #4156
shawnsheridan
Thank you
      07-28-2013, 12:08 PM   #4157
thebadboy
Drives: 335i f30
is it possible to play video coding from a USB key
thanks
      07-28-2013, 12:10 PM   #4158
shawnsheridan
thanks
Only if you have NBT Head Unit.
